14 x 5.5 date code question #2932225
06/11/21 10:10 AM
06/11/21 10:10 AM
Indiana
68_661charger Offline OP
Indiana
On a kelsey hayes 14 x 5.5 steel wheel with a k2 9 underneath does the 9 mean 69 or 79? It's smooth dome 4 nub 5 lug with 1 extra hole between 2 lug holes, maybe originally white. The k2 9 is on the band inside where the tire is mounted with nothing by the valve stem. It was in my 70 charger Road wheel car but who knows if it was original. Thanks just wanting to educate myself.
Re: 14 x 5.5 date code question [Re: 68_661charger] #2932234
06/11/21 10:43 AM
06/11/21 10:43 AM
MD
floyd Online content
floyd  Online Content
MD
The “9” could mean either year I suppose but I bet it’s a 1969 rim. Maybe post a picture?
Re: 14 x 5.5 date code question [Re: floyd] #2932236
06/11/21 10:47 AM
06/11/21 10:47 AM
Indiana
Indiana
Here's a pic. By the lug holes is also stamped G and 11.
Re: 14 x 5.5 date code question [Re: 68_661charger] #2932241
06/11/21 11:13 AM
06/11/21 11:13 AM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
You should see a part number near valve stem as well. This will tell the story.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 14 x 5.5 date code question [Re: 70gtx440dana] #2932307
06/11/21 04:42 PM
06/11/21 04:42 PM
Indiana
Indiana
I blasted that area of the rim and no part number but it does say k2 9 11 on left side of valve and 26 55 or 5.5 on right
Re: 14 x 5.5 date code question [Re: 68_661charger] #2932334
06/11/21 07:33 PM
06/11/21 07:33 PM
Lansing, MI
Lansing, MI
So, 11/26/69 dated 5.5" wheel. Not sure why no part number. According to White book that would be a 2944236 wheel.
Re: 14 x 5.5 date code question [Re: 70gtx440dana] #2932336
06/11/21 07:42 PM
06/11/21 07:42 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Lots of wheels were made without stamped part numbers.
Re: 14 x 5.5 date code question [Re: Alaskan_TA] #2932381
06/11/21 10:30 PM
06/11/21 10:30 PM
Indiana
Indiana
Alright, thank you all.
Re: 14 x 5.5 date code question [Re: Alaskan_TA] #2932419
06/12/21 08:16 AM
06/12/21 08:16 AM
MD
MD
Yep, I had an early 390 15X7 with no part number awhile back.
Re: 14 x 5.5 date code question [Re: floyd] #2934971
06/20/21 08:14 AM
06/20/21 08:14 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The date on that rim is 11/26/1969. It has no date because it is a Kelsey Hayes rim. Dated rims were made by Motor Wheel. The White book is wrong about that part number.
Re: 14 x 5.5 date code question [Re: 68_661charger] #2935032
06/20/21 12:20 PM
06/20/21 12:20 PM
Ohio
carteravs Offline
carteravs  Offline
Ohio
Looking at the area around the lug bolt holes, I'd say it's newer than '69.
Re: 14 x 5.5 date code question [Re: carteravs] #2942311
07/12/21 12:12 PM
07/12/21 12:12 PM
Indiana
Indiana
All good info thanks. What is the extra hole for in between two of the lug holes?
Re: 14 x 5.5 date code question [Re: m46rat] #2942323
07/12/21 12:54 PM
07/12/21 12:54 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Are you sure you dont mean "It has no PART NUMBER because it is a Kelsey Hayes rim. PART NUMBERED rims were made by Motor Wheel.
Its origin is quite likely from your 1970 Dodge B-body
It could be used as well for someone wanting to put a B F Goodrich F-78-14 spacesaver tire on, hence the extra hole.
Re: 14 x 5.5 date code question [Re: mccannix] #2943319
07/15/21 08:29 AM
07/15/21 08:29 AM
blewbyu Offline
blewbyu  Offline
Here you go for reference
Re: 14 x 5.5 date code question [Re: blewbyu] #2943915
07/16/21 01:01 PM
07/16/21 01:01 PM
Indiana
Indiana
Cool glad I asked
