Re: 14 x 5.5 date code question
[Re: floyd]
#2932236
06/11/21 10:47 AM
06/11/21 10:47 AM
Posts: 949 Indiana
68_661charger
Indiana
Here's a pic. By the lug holes is also stamped G and 11.
[Re: 68_661charger]
#2932241
06/11/21 11:13 AM
06/11/21 11:13 AM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
You should see a part number near valve stem as well. This will tell the story.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 68_661charger]
#2932334
06/11/21 07:33 PM
06/11/21 07:33 PM
70gtx440dana
Lansing, MI
So, 11/26/69 dated 5.5" wheel. Not sure why no part number. According to White book that would be a 2944236 wheel.
[Re: Alaskan_TA]
#2932419
06/12/21 08:16 AM
06/12/21 08:16 AM
Posts: 4,115 MD
floyd
MD
Lots of wheels were made without stamped part numbers. Yep, I had an early 390 15X7 with no part number awhile back.
[Re: m46rat]
#2942323
07/12/21 12:54 PM
07/12/21 12:54 PM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
The date on that rim is 11/26/1969. It has no date because it is a Kelsey Hayes rim. Dated rims were made by Motor Wheel. The White book is wrong about that part number. Are you sure you dont mean "It has no PART NUMBER because it is a Kelsey Hayes rim. PART NUMBERED rims were made by Motor Wheel. Its origin is quite likely from your 1970 Dodge B-body It could be used as well for someone wanting to put a B F Goodrich F-78-14 spacesaver tire on, hence the extra hole.
