Aftermarket street/strip car ignition #2932562
06/12/21 05:36 PM
06/12/21 05:36 PM
Big Western Pencilveinya
U
Uncle Barry Offline OP
U
Who today makes a good ignition system for my car. I think I may retire my old MP ECU and want something that is dependable and will make some RPM's. No crank triggers.
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2932564
06/12/21 05:47 PM
06/12/21 05:47 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I like the MSD 6al 2
Nice street strip ignition, that is what i use it for
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2932572
06/12/21 06:06 PM
06/12/21 06:06 PM
AndyF Offline
AndyF  Offline
For a race car the standard setup of a MSD billet distributor and a MSD 6 box seems to work for most people. If it is a street/strip kind of deal where you want vacuum advance then the choices are a little tougher.
Re: Aftermarket street/strip car ignition [Re: AndyF] #2932593
06/12/21 07:06 PM
06/12/21 07:06 PM
U
U
I guess I should have added that I don't run vacuum advance. It's a recurved distributor and is at full advance around 2500 rpm. Just curious if there was anything out there other than MSD. Just seeing what other options there are.
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2932610
06/12/21 08:02 PM
06/12/21 08:02 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Check out Progession Ignition.
America First!
Re: Aftermarket street/strip car ignition [Re: carnut68] #2932654
06/12/21 10:30 PM
06/12/21 10:30 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Progression Ignition stuff sure is nice.
I would buy another in a heartbeat.
Re: Aftermarket street/strip car ignition [Re: AndyF] #2932658
06/12/21 10:56 PM
06/12/21 10:56 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I agree, I've had the 6AL and my billet dist for 22 years with no issues
eBay-cdwmotorsports
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2932779
06/13/21 12:11 PM
06/13/21 12:11 PM
AndyF Offline
AndyF  Offline
If you are looking for something other than MSD then that is the question you should ask. You'll get better answers if you ask that question.
Re: Aftermarket street/strip car ignition [Re: AndyF] #2932807
06/13/21 01:16 PM
06/13/21 01:16 PM
U
U
I'm open to MSD ignition. Just seeing other options too. I don't really know about aftermarket ignition systems so I asked that question. I don't even know what distributor, such as an MSD pro billet, will clear an Edelbrock Victor Jr Hemi head and stamped steel valve cover and a factory air cleaner base. I'm just testing the waters and I'll probably ask more questions before I make a choice. Thanks for all the responses.
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2932811
06/13/21 01:24 PM
06/13/21 01:24 PM
moparx Offline
moparx  Offline
why don't you want to run vacuum advance ? race only engine i can understand, but if you do any street miles at all, vacuum advance is your friend.
it will take a little tuning of the advance curve inside the distributor, plus adjusting the can [and possibly changing it for a different unit] through the hose nipple, but it will be well worth it in the end.
see the article by e-booger on the "mopar action" magazine site for the how to.
beer
Re: Aftermarket street/strip car ignition [Re: moparx] #2932816
06/13/21 01:37 PM
06/13/21 01:37 PM
U
U
beer
We just always run mechanical advance on our stuff for years and worked flawlessly with no issues street driving. shruggy
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2932819
06/13/21 01:50 PM
06/13/21 01:50 PM
moparx Offline
moparx  Offline
i'm not implying your combo[s] did not work good as you had them set up, it's just that they could have had the potential to work better, especially in gas mileage at light cruise conditions.
and when sorted out well, the vacuum advance does not take anything away from whatever mechanical setup you currently run. at WOT, the vacuum is practically nil, so it has no effect on a race tune.
i'm a fan of vacuum advance, so this is just my opinion. your mileage will vary.
beer
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2932850
06/13/21 04:09 PM
06/13/21 04:09 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I have been using a Crane Ignition box with a MP race Hemi tach drive distributor in my Hemi and I would buy the Crane box again. No problems. Mine is the Fireball Hi 6 purchased in the late 90s IIRC.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2933011
06/13/21 11:25 PM
06/13/21 11:25 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
MSD 6AL is your friend.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Aftermarket street/strip car ignition [Re: BloFish] #2933042
06/14/21 02:01 AM
06/14/21 02:01 AM
Northern Bavaria / Germany
MichaelF Offline
MichaelF  Offline
I used the msd streetfire box with good results.....a little cheaper than the 6-AL, has got a rev limiter too and performed flawlessly.
Michael
Re: Aftermarket street/strip car ignition [Re: MichaelF] #2933073
06/14/21 08:23 AM
06/14/21 08:23 AM
an8sec70cuda Offline
MSD 6AL-2 programmable. (6530)
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aftermarket street/strip car ignition [Re: an8sec70cuda] #2933109
06/14/21 10:13 AM
06/14/21 10:13 AM
PA
moparacer Offline
moparacer  Offline
PA
Used 6AL's for years and still do on my Barracuda, and have a 6AL2 on my Dart.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Aftermarket street/strip car ignition [Re: MichaelF] #2933110
06/14/21 10:23 AM
06/14/21 10:23 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Michael
I have a powerwagon that overheated the coil a few times with stock Electronic ign setup. Switched to a streetfire (atleast 6 years ago) and it has been perfect.
Bought a used 6AL to run on the hot rod with a electronic chrysler distributor and it has been fine too.
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2933124
06/14/21 10:57 AM
06/14/21 10:57 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
What’s considered Some RPMs ?
What are you shifting at now ?
I love the Firecore distributor with vacuum advance - Adjustability is awesome and easy , ported vacuum - Use factory distributor cap and decent wires
Older Direct Connection Mopar Chrome ECU or the Older Standard LX101 ECU ignition modules
I considered upgrading to a MSD Streetfire module or Pertronix Digital HP when I was chasing RPM issues until
Coils and Ballast
But on a 500 HP Street car , in all honestly what would I gain ?
Starts awesome , idles awesome , destroys the tires awesome , shift around 5400 RPMs with my cam and valve train
Putting together a great quality Factory Stock Type Performance Mopar Ignition System is a little harder today with all this Chinese junk
I guess in reality that’s the biggest issue
I found all my new old stock ignition components on EBay and swap meets
The Firecore distributor, so far so great on the street
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Aftermarket street/strip car ignition [Re: Uncle Barry] #2933183
06/14/21 12:46 PM
06/14/21 12:46 PM
Cab_Burge Online work
Cab_Burge  Online Work
I wouldn't buy and try to use a MSD 6AL digital, I know to many people who had them fail down twocents I've never used the MSD street # 6 series boxes but I know a lot of racers that use them on their bracket cars shruggy
I still like and use MSD race ignitions on my race cars, 7AL2, 7C, grid and so on up
