Re: Aftermarket street/strip car ignition
[Re: Uncle Barry]
#2932564
06/12/21 05:47 PM
06/12/21 05:47 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
I like the MSD 6al 2 Nice street strip ignition, that is what i use it for
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Uncle Barry]
#2932572
06/12/21 06:06 PM
06/12/21 06:06 PM
Posts: 31,049 Oregon
AndyF
Who today makes a good ignition system for my car. I think I may retire my old MP ECU and want something that is dependable and will make some RPM's. No crank triggers. For a race car the standard setup of a MSD billet distributor and a MSD 6 box seems to work for most people. If it is a street/strip kind of deal where you want vacuum advance then the choices are a little tougher.
[Re: AndyF]
#2932593
06/12/21 07:06 PM
06/12/21 07:06 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
Who today makes a good ignition system for my car. I think I may retire my old MP ECU and want something that is dependable and will make some RPM's. No crank triggers. For a race car the standard setup of a MSD billet distributor and a MSD 6 box seems to work for most people. If it is a street/strip kind of deal where you want vacuum advance then the choices are a little tougher. I guess I should have added that I don't run vacuum advance. It's a recurved distributor and is at full advance around 2500 rpm. Just curious if there was anything out there other than MSD. Just seeing what other options there are.
[Re: Uncle Barry]
#2932610
06/12/21 08:02 PM
06/12/21 08:02 PM
Posts: 3,201 Md.
carnut68
Md.
Who today makes a good ignition system for my car. I think I may retire my old MP ECU and want something that is dependable and will make some RPM's. No crank triggers. For a race car the standard setup of a MSD billet distributor and a MSD 6 box seems to work for most people. If it is a street/strip kind of deal where you want vacuum advance then the choices are a little tougher. I guess I should have added that I don't run vacuum advance. It's a recurved distributor and is at full advance around 2500 rpm. Just curious if there was anything out there other than MSD. Just seeing what other options there are. Check out Progession Ignition.
America First!
[Re: AndyF]
#2932658
06/12/21 10:56 PM
06/12/21 10:56 PM
Posts: 1,460 Martinsville, IN
cdwmotorsports
Martinsville, IN
Who today makes a good ignition system for my car. I think I may retire my old MP ECU and want something that is dependable and will make some RPM's. No crank triggers. For a race car the standard setup of a MSD billet distributor and a MSD 6 box seems to work for most people. If it is a street/strip kind of deal where you want vacuum advance then the choices are a little tougher. I agree, I've had the 6AL and my billet dist for 22 years with no issues
eBay-cdwmotorsports
[Re: Uncle Barry]
#2932779
06/13/21 12:11 PM
06/13/21 12:11 PM
AndyF
Who today makes a good ignition system for my car. I think I may retire my old MP ECU and want something that is dependable and will make some RPM's. No crank triggers. For a race car the standard setup of a MSD billet distributor and a MSD 6 box seems to work for most people. If it is a street/strip kind of deal where you want vacuum advance then the choices are a little tougher. I guess I should have added that I don't run vacuum advance. It's a recurved distributor and is at full advance around 2500 rpm. Just curious if there was anything out there other than MSD. Just seeing what other options there are. If you are looking for something other than MSD then that is the question you should ask. You'll get better answers if you ask that question.
[Re: AndyF]
#2932807
06/13/21 01:16 PM
06/13/21 01:16 PM
Uncle Barry
Who today makes a good ignition system for my car. I think I may retire my old MP ECU and want something that is dependable and will make some RPM's. No crank triggers. For a race car the standard setup of a MSD billet distributor and a MSD 6 box seems to work for most people. If it is a street/strip kind of deal where you want vacuum advance then the choices are a little tougher. I guess I should have added that I don't run vacuum advance. It's a recurved distributor and is at full advance around 2500 rpm. Just curious if there was anything out there other than MSD. Just seeing what other options there are. If you are looking for something other than MSD then that is the question you should ask. You'll get better answers if you ask that question. I'm open to MSD ignition. Just seeing other options too. I don't really know about aftermarket ignition systems so I asked that question. I don't even know what distributor, such as an MSD pro billet, will clear an Edelbrock Victor Jr Hemi head and stamped steel valve cover and a factory air cleaner base. I'm just testing the waters and I'll probably ask more questions before I make a choice. Thanks for all the responses.
[Re: Uncle Barry]
#2932811
06/13/21 01:24 PM
06/13/21 01:24 PM
Posts: 19,464 north of coder
moparx
why don't you want to run vacuum advance ? race only engine i can understand, but if you do any street miles at all, vacuum advance is your friend. it will take a little tuning of the advance curve inside the distributor, plus adjusting the can [and possibly changing it for a different unit] through the hose nipple, but it will be well worth it in the end. see the article by e-booger on the "mopar action" magazine site for the how to.
[Re: moparx]
#2932816
06/13/21 01:37 PM
06/13/21 01:37 PM
Uncle Barry
why don't you want to run vacuum advance ? race only engine i can understand, but if you do any street miles at all, vacuum advance is your friend. it will take a little tuning of the advance curve inside the distributor, plus adjusting the can [and possibly changing it for a different unit] through the hose nipple, but it will be well worth it in the end. see the article by e-booger on the "mopar action" magazine site for the how to. We just always run mechanical advance on our stuff for years and worked flawlessly with no issues street driving.
[Re: Uncle Barry]
#2932819
06/13/21 01:50 PM
06/13/21 01:50 PM
moparx
i'm not implying your combo[s] did not work good as you had them set up, it's just that they could have had the potential to work better, especially in gas mileage at light cruise conditions. and when sorted out well, the vacuum advance does not take anything away from whatever mechanical setup you currently run. at WOT, the vacuum is practically nil, so it has no effect on a race tune. i'm a fan of vacuum advance, so this is just my opinion. your mileage will vary.
[Re: Uncle Barry]
#2932850
06/13/21 04:09 PM
06/13/21 04:09 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Who today makes a good ignition system for my car. I think I may retire my old MP ECU and want something that is dependable and will make some RPM's. No crank triggers. I have been using a Crane Ignition box with a MP race Hemi tach drive distributor in my Hemi and I would buy the Crane box again. No problems. Mine is the Fireball Hi 6 purchased in the late 90s IIRC. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: MichaelF]
#2933073
06/14/21 08:23 AM
06/14/21 08:23 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
MSD 6AL-2 programmable. (6530)
[Re: an8sec70cuda]
#2933109
06/14/21 10:13 AM
06/14/21 10:13 AM
Posts: 2,513 PA
moparacer
PA
Used 6AL's for years and still do on my Barracuda, and have a 6AL2 on my Dart.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: MichaelF]
#2933110
06/14/21 10:23 AM
06/14/21 10:23 AM
Posts: 2,094 central texas
krautrock
central texas
I used the msd streetfire box with good results.....a little cheaper than the 6-AL, has got a rev limiter too and performed flawlessly.
Michael I have a powerwagon that overheated the coil a few times with stock Electronic ign setup. Switched to a streetfire (atleast 6 years ago) and it has been perfect. Bought a used 6AL to run on the hot rod with a electronic chrysler distributor and it has been fine too.
[Re: Uncle Barry]
#2933124
06/14/21 10:57 AM
06/14/21 10:57 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
What’s considered Some RPMs ?
What are you shifting at now ?
I love the Firecore distributor with vacuum advance - Adjustability is awesome and easy , ported vacuum - Use factory distributor cap and decent wires
Older Direct Connection Mopar Chrome ECU or the Older Standard LX101 ECU ignition modules
I considered upgrading to a MSD Streetfire module or Pertronix Digital HP when I was chasing RPM issues until
Coils and Ballast
But on a 500 HP Street car , in all honestly what would I gain ?
Starts awesome , idles awesome , destroys the tires awesome , shift around 5400 RPMs with my cam and valve train
Putting together a great quality Factory Stock Type Performance Mopar Ignition System is a little harder today with all this Chinese junk I guess in reality that’s the biggest issue
I found all my new old stock ignition components on EBay and swap meets
The Firecore distributor, so far so great on the street
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
