Motor Mount Bolt Size #2920109
05/08/21 06:14 PM
05/08/21 06:14 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Can anyone tell me what size the driver's side motor mount to frame bolt is supposed to be? Is it 7/16 by 3-3/4 or something like that? The car is a 71 Charger with a 440.
The one installed now appears to be slightly too small in diameter (like it's metric or something) and it had a nut and washer installed on the backside even though there is a welded nut there.
I would like to just use a hardware store bolt if possible, it's just a driver.
Thank you.
Greg
Re: Motor Mount Bolt Size [Re: GregY] #2920119
05/08/21 06:32 PM
05/08/21 06:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure the original welded nut isn't striped? That may be the reason for the undersized bolt.
Re: Motor Mount Bolt Size [Re: GregY] #2920124
05/08/21 06:53 PM
05/08/21 06:53 PM
n.c.
geo. Offline
geo.  Offline
n.c.
pretty sure you're correct at 7/16" coarse thread. I'd try running a tap through it. I imagine a smaller bolt would allow a loose fit in the hole so engine could rock if bolt isn't real tight.
If engine is out weld a nut to it, or replace the mount.
Re: Motor Mount Bolt Size [Re: geo.] #2920164
05/08/21 08:22 PM
05/08/21 08:22 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Thanks guys. The welded nut being stripped is a good thought, I will check that out. The motor is unfortunately in the car, I had to undo the mount to lift the motor to install my new steering box.
Re: Motor Mount Bolt Size [Re: stumpy] #2920190
05/08/21 09:40 PM
05/08/21 09:40 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Why would anyone put a stripe on a nut?
Re: Motor Mount Bolt Size [Re: Kern Dog] #2920194
05/08/21 10:03 PM
05/08/21 10:03 PM
Me thinks he means stripped, not stripe shruggy
Re: Motor Mount Bolt Size [Re: Kern Dog] #2920208
05/08/21 10:21 PM
05/08/21 10:21 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Its a mopar, everything gets a paint daub
Re: Motor Mount Bolt Size [Re: Kern Dog] #2920234
05/08/21 11:42 PM
05/08/21 11:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
To make silly people ask questions. shruggy
Re: Motor Mount Bolt Size [Re: stumpy] #2920290
05/09/21 08:40 AM
05/09/21 08:40 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
I got all excited when I saw there were 4 more responses to my question...
Re: Motor Mount Bolt Size [Re: GregY] #2920317
05/09/21 10:05 AM
05/09/21 10:05 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
But, did you fix the motor mount yet? If there is enough space, you can jut add a nut on the outside of the threaded block to tighten the moror mount bolt. That won't pass a restoration test, but it will function on a driven car. Gene
Re: Motor Mount Bolt Size [Re: poorboy] #2920333
05/09/21 10:46 AM
05/09/21 10:46 AM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
Just measured 1 it is 7/16 " x 4 1/2" long coarse thread
Re: Motor Mount Bolt Size [Re: GVH] #2920374
05/09/21 12:18 PM
05/09/21 12:18 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Thanks guys. I can just put it back together with the nut on it, but I was struggling with it to the point of frustration because there is not a lot of room to feed the nut up in there and get the bolt to engage with it. So I gave up and was wondering why it wasn't "right" and if there was a way I could make it so.
One way or another I will figure it out. I am excited to try my new Firm Feel Stage 2 steering box, so I am anxious to get everything back together.
