Re: Motor Mount Bolt Size
[Re: stumpy]
#2920190
05/08/21 09:40 PM
05/08/21 09:40 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Are you sure the original welded nut isn't striped? That may be the reason for the undersized bolt. Why would anyone put a stripe on a nut?
[Re: Kern Dog]
#2920194
05/08/21 10:03 PM
05/08/21 10:03 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Are you sure the original welded nut isn't striped? That may be the reason for the undersized bolt. Why would anyone put a stripe on a nut? Me thinks he means stripped, not stripe ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Kern Dog]
#2920208
05/08/21 10:21 PM
05/08/21 10:21 PM
Posts: 1,413 Central Pa
moparjim79
Central Pa
Are you sure the original welded nut isn't striped? That may be the reason for the undersized bolt. Why would anyone put a stripe on a nut? Its a mopar, everything gets a paint daub
[Re: Kern Dog]
#2920234
05/08/21 11:42 PM
05/08/21 11:42 PM
Posts: 32,985 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Are you sure the original welded nut isn't striped? That may be the reason for the undersized bolt. Why would anyone put a stripe on a nut? To make silly people ask questions. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: GregY]
#2920317
05/09/21 10:05 AM
05/09/21 10:05 AM
Posts: 10,644 Freeport IL USA
poorboy
Freeport IL USA
I got all excited when I saw there were 4 more responses to my question...
But, did you fix the motor mount yet? If there is enough space, you can jut add a nut on the outside of the threaded block to tighten the moror mount bolt. That won't pass a restoration test, but it will function on a driven car. Gene
[Re: poorboy]
#2920333
05/09/21 10:46 AM
05/09/21 10:46 AM
Posts: 302 Ontario, Canada
GVH
Ontario, Canada
Just measured 1 it is 7/16 " x 4 1/2" long coarse thread
