Air Cleaner #2904232
03/30/21 10:06 AM
03/30/21 10:06 AM
Ontario, Canada
GVH Offline OP
GVH  Offline OP
Ontario, Canada
Want to refinish my 71 340 air cleaner . It is in not bad condition what would best a stripper or a light medium ,not wanting to warp?
Who supplies the best spray can wrinkle paint ? Have heard that Harley Davidson has a good one .
TYIA.
Gerry
Re: Air Cleaner [Re: GVH] #2904233
03/30/21 10:13 AM
03/30/21 10:13 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Spray on oven cleaner. Put a/c in plastic bag to slow the evaporation. I like the lemon scented stuff.
Re: Air Cleaner [Re: GVH] #2904251
03/30/21 10:56 AM
03/30/21 10:56 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i just cleaned mine and lightly sprayed semi flat over it..looks brand new and still has all its orig texture..
Re: Air Cleaner [Re: ph23vo] #2904464
03/31/21 06:28 AM
03/31/21 06:28 AM
Ontario, Canada
GVH Offline OP
GVH  Offline OP
Ontario, Canada
looks good but mine is peeling
Re: Air Cleaner [Re: GVH] #2904527
03/31/21 10:13 AM
03/31/21 10:13 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
3M paint stripping disc to get the outside stuff off and hand sand the interior or use paint stripper. You can sandblast the inside, but your likely to get sand packed up under the baffles that will have to be dug back out.
Detroit Muscle Technologies sells new lid gaskets. ECS sells new filter decals.
They make wrinkle powder coating that a lot of people swear by vs paint can stuff.
Re: Air Cleaner [Re: Neil] #2905213
04/02/21 07:59 AM
04/02/21 07:59 AM
Ontario, Canada
GVH Offline OP
GVH  Offline OP
Ontario, Canada
who makes this wrinkle powder you mentioned ?
Re: Air Cleaner [Re: GVH] #2905281
04/02/21 10:30 AM
04/02/21 10:30 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: Air Cleaner [Re: Neil] #2905294
04/02/21 10:52 AM
04/02/21 10:52 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
just media blast it and skip the mess and headaches of strippers and sanding discs. 50-100 or 100-200 glass and you will never warp it unless your standing on it to blast. if you powdercoat your coater most likely will have the facilities to blast it.
if you do have a good blaster locally that uses fine medias just take it there.
Re: Air Cleaner [Re: chrisf] #2905396
04/02/21 02:09 PM
04/02/21 02:09 PM
Ontario Canada
Bennoel 10 Offline
Bennoel 10  Offline
Ontario Canada
I agree 👍
That's exactly what I did (glass beads) in a sandblasting cabinet. Then I just used wrinkle paint from local auto store (Canadian Tire). Heated up the air cleaner in an oven first and laid on the paint thick. Turned out good. I've done a few like that with good results and long lasting.
Re: Air Cleaner [Re: Bennoel 10] #2905399
04/02/21 02:12 PM
04/02/21 02:12 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I hesitate to take stuff to blasters as many use sand and high pressure as they do trailers and other thick metals. Those are the types of guys who will wreck thin sheetmetal parts and then shrug their shoulders and say not my problem.
Re: Air Cleaner [Re: GVH] #2905702
04/03/21 10:16 AM
04/03/21 10:16 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
TYIA.
Gerry
I have a big oven here at my shop and powder coat all my unsilenced air cleaners as well as Hemi valve covers. Send it to me, I'll do it for $75.
Re: Air Cleaner [Re: HEMICUDA] #2906195
04/04/21 12:29 PM
04/04/21 12:29 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I'd take Mike up on his offer. $75 is a great price. I think that powder coating is more durable than paint.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
