Re: Air Cleaner
[Re: GVH]
#2904233
03/30/21 10:13 AM
03/30/21 10:13 AM
Posts: 1,841 South Bend
John Brown
South Bend
Spray on oven cleaner. Put a/c in plastic bag to slow the evaporation. I like the lemon scented stuff.
Re: Air Cleaner
[Re: chrisf]
#2905396
04/02/21 02:09 PM
04/02/21 02:09 PM
Posts: 181 Ontario Canada
Bennoel 10
Ontario Canada
just media blast it and skip the mess and headaches of strippers and sanding discs. 50-100 or 100-200 glass and you will never warp it unless your standing on it to blast. if you powdercoat your coater most likely will have the facilities to blast it. if you do have a good blaster locally that uses fine medias just take it there. I agree 👍 That's exactly what I did (glass beads) in a sandblasting cabinet. Then I just used wrinkle paint from local auto store (Canadian Tire). Heated up the air cleaner in an oven first and laid on the paint thick. Turned out good. I've done a few like that with good results and long lasting.
Re: Air Cleaner
[Re: GVH]
#2905702
04/03/21 10:16 AM
04/03/21 10:16 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Want to refinish my 71 340 air cleaner . It is in not bad condition what would best a stripper or a light medium ,not wanting to warp? Who supplies the best spray can wrinkle paint ? Have heard that Harley Davidson has a good one . TYIA. Gerry I have a big oven here at my shop and powder coat all my unsilenced air cleaners as well as Hemi valve covers. Send it to me, I'll do it for $75.
