Re: Dash Radio Jamb Nuts
[Re: CDN72SE]
#2900129
03/17/21 04:12 PM
03/17/21 04:12 PM
Posts: 74 Sin City
calif67rt
Sin City
I tried Grainger but not McMaster-Carr. What did you search for on Ebay? Radio nuts? Jamb nuts? Panel nuts? I always end up with a bunch of extraneous items whenever I look for something on Ebay. Based on what I tried at Lowes it is 1/2 x 20 thread, a fine thread.
[Re: calif67rt]
#2900299
03/18/21 09:49 AM
03/18/21 09:49 AM
Posts: 10,711 North Dakota
6PakBee
North Dakota
That 1/2-20 is a problem. If it was 1/2-28, they are every where.
[Re: calif67rt]
#2900342
03/18/21 12:16 PM
03/18/21 12:16 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I tried Grainger but not McMaster-Carr. What did you search for on Ebay? Radio nuts? Jamb nuts? Panel nuts? I always end up with a bunch of extraneous items whenever I look for something on Ebay. Based on what I tried at Lowes it is 1/2 x 20 thread, a fine thread. Wide selection of 1/2-20 nuts at McMaster Carr, search jamb nuts, type in 1/2-20 thread in the size box, even left handed 1/2-20 jamb nuts are available, when you click on a product number the "product description" text will pop up, you can then check the height specs of the assorted nuts offered as well as material or country of origin Mike
[Re: calif67rt]
#2901235
03/21/21 02:33 AM
03/21/21 02:33 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I tried McMaster-Carr. They had the nuts but they were 5/16" thick. I need 1/8" thick. I appreciate the help. If anyone has any other ideas I would appreciate it. 3/16" (.186) thick do the trick?... vs 1/8 (.125), .062 (1/16") difference? Did more looking, what you want by description is a "panel nut", not a jamb nut....
[Re: Cuda340]
#2902089
03/23/21 03:28 PM
03/23/21 03:28 PM
Posts: 2,730 541 slobovia
A990
541 slobovia
Try Moparts member BIGMONEYLEWIS he owns an antique radio restoration shop He closed up and liquidated everything.
[Re: calif67rt]
#2902203
03/23/21 10:10 PM
03/23/21 10:10 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Try hitting some thrift shops or antique malls. You may find some 70s/80s aftermarket radios with the same nuts.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#2902279
03/24/21 08:55 AM
03/24/21 08:55 AM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I tried McMaster-Carr. They had the nuts but they were 5/16" thick. I need 1/8" thick. I appreciate the help. If anyone has any other ideas I would appreciate it. I'd just buy the 5/16" pieces that are the correct thread. Then machine down the thickness until it's a size that will work.
[Re: burdar]
#2902287
03/24/21 09:22 AM
03/24/21 09:22 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I tried McMaster-Carr. They had the nuts but they were 5/16" thick. I need 1/8" thick. I appreciate the help. If anyone has any other ideas I would appreciate it. I'd just buy the 5/16" pieces that are the correct thread. Then machine down the thickness until it's a size that will work. He'd have a better head start with the 3/16" thick nuts...
