Dash Radio Jamb Nuts #2899754
03/16/21 03:57 PM
03/16/21 03:57 PM
Sin City
calif67rt Offline OP
Sin City
They say the devil is in the details. I am getting ready to put the dash in my 67 Coronet Convertible. I started looking for the jamb nuts to attach the radio to the dash thru the knobs. I only had 1 nut. So I have tried hardware stores, auto parts stores, electrical supply houses and local friends. No one has these nuts. My last choice is to try to go to the local wrecking yards to find it. But it is unlikely they will have any cars old enough that still have these type f radios. Does anyone have any idea where I can get these nuts (see photo attached)?
Radio Jamb Nut
Re: Dash Radio Jamb Nuts [Re: calif67rt] #2899933
03/17/21 12:42 AM
03/17/21 12:42 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Lots of electrical test equipment like meters, with rotary knobs use such nuts. But be aware; there are many variants with such nuts. Namely exact diameter & thread pitch.
Re: Dash Radio Jamb Nuts [Re: PhillyRag] #2900038
03/17/21 12:22 PM
03/17/21 12:22 PM
moparx Offline
moparx  Offline
another place to try would be mcmaster-carr or grainger.
but as stated, you would need to know the thread pitch of the nuts.
beer
Re: Dash Radio Jamb Nuts [Re: moparx] #2900126
03/17/21 04:07 PM
03/17/21 04:07 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Went through that search myself and was able to find a pair of OEM on eBay.
Re: Dash Radio Jamb Nuts [Re: CDN72SE] #2900129
03/17/21 04:12 PM
03/17/21 04:12 PM
Sin City
Sin City
I tried Grainger but not McMaster-Carr. What did you search for on Ebay? Radio nuts? Jamb nuts? Panel nuts? I always end up with a bunch of extraneous items whenever I look for something on Ebay. Based on what I tried at Lowes it is 1/2 x 20 thread, a fine thread.
Re: Dash Radio Jamb Nuts [Re: calif67rt] #2900299
03/18/21 09:49 AM
03/18/21 09:49 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
That 1/2-20 is a problem. If it was 1/2-28, they are every where.
Re: Dash Radio Jamb Nuts [Re: calif67rt] #2900342
03/18/21 12:16 PM
03/18/21 12:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Wide selection of 1/2-20 nuts at McMaster Carr, search jamb nuts, type in 1/2-20 thread in the size box, even left handed 1/2-20 jamb nuts are available, when you click on a product number the "product description" text will pop up, you can then check the height specs of the assorted nuts offered as well as material or country of origin
Mike
Re: Dash Radio Jamb Nuts [Re: DAYCLONA] #2901062
03/20/21 12:48 PM
03/20/21 12:48 PM
Sin City
Sin City
I tried McMaster-Carr. They had the nuts but they were 5/16" thick. I need 1/8" thick. I appreciate the help. If anyone has any other ideas I would appreciate it.
Re: Dash Radio Jamb Nuts [Re: calif67rt] #2901082
03/20/21 02:10 PM
03/20/21 02:10 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
any local wrecking yards with old cars that you could check ??
Re: Dash Radio Jamb Nuts [Re: calif67rt] #2901235
03/21/21 02:33 AM
03/21/21 02:33 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
3/16" (.186) thick do the trick?... vs 1/8 (.125), .062 (1/16") difference?
Did more looking, what you want by description is a "panel nut", not a jamb nut....
Re: Dash Radio Jamb Nuts [Re: DAYCLONA] #2901240
03/21/21 04:53 AM
03/21/21 04:53 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
Look in the lamp section at the hardware store. The threaded tube used to attach bulb sockets on lamps uses the same nut
Re: Dash Radio Jamb Nuts [Re: solarguy] #2901329
03/21/21 12:53 PM
03/21/21 12:53 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Try these guys, https://rainbowboltsupply.com/ I have had very good luck with them on finding odd and off size nuts and bolts.
My Monster are real!
Living within your means makes life pretty easy.
Re: Dash Radio Jamb Nuts [Re: DAYCLONA] #2901985
03/23/21 11:45 AM
03/23/21 11:45 AM
Sin City
Sin City
Thanks. I tried panel nuts and found the 1/2 x 28 x 3/16" nuts. But I need 1/2 by 20. So still doesn't work. Also, the last time I went to junk yards out here (4-5 years ago) they didn't have any cars from the 60's and 70's. There weren't as nearly many of those cars out here and people are now holding on to them.
Re: Dash Radio Jamb Nuts [Re: calif67rt] #2902087
03/23/21 03:27 PM
03/23/21 03:27 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Try Moparts member BIGMONEYLEWIS he owns an antique radio restoration shop
Re: Dash Radio Jamb Nuts [Re: Cuda340] #2902089
03/23/21 03:28 PM
03/23/21 03:28 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
He closed up and liquidated everything.
Re: Dash Radio Jamb Nuts [Re: calif67rt] #2902203
03/23/21 10:10 PM
03/23/21 10:10 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Try hitting some thrift shops or antique malls. You may find some 70s/80s aftermarket radios with the same nuts.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Dash Radio Jamb Nuts [Re: RoadRunner] #2902279
03/24/21 08:55 AM
03/24/21 08:55 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
Quote
I'd just buy the 5/16" pieces that are the correct thread. Then machine down the thickness until it's a size that will work.
Re: Dash Radio Jamb Nuts [Re: burdar] #2902287
03/24/21 09:22 AM
03/24/21 09:22 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted by burdar
Quote
He'd have a better head start with the 3/16" thick nuts... smile
Re: Dash Radio Jamb Nuts [Re: DAYCLONA] #2903807
03/28/21 09:53 PM
03/28/21 09:53 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
