front S/S spring hanger mounting holes #289101
04/15/09 01:04 PM
04/15/09 01:04 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Ive tried searching previous posts on this subject but couldnt find the answer im looking for.On super stock spring front hangers with two sets of mounting holes,which set should be used and what is the difference between the upper and lower holes?Thanks.
Re: front S/S spring hanger mounting holes [Re: jst19600] #289102
04/15/09 01:07 PM
04/15/09 01:07 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Use the upper hole.....the further up the better.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: front S/S spring hanger mounting holes [Re: Steve1118] #289103
04/15/09 01:18 PM
04/15/09 01:18 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Why the upper hole Steve?
Re: front S/S spring hanger mounting holes [Re: jst19600] #289104
04/15/09 01:32 PM
04/15/09 01:32 PM
AndyF Offline
AndyF  Offline
On the hangers I make (Mancini, Firm Feel, Moparts P&S, Eberg, etc sell my stuff) the lower hole is the stock ride height. The upper hole lowers the car as well as changing the geometry a bit.
I've had some racers order custom hangers from me that dropped the front eye point. They wanted to lower the eye bolt for a softer hit. So some people want to go with the upper hole and some use the lower hole and some folks want an even lower eye bolt hole.
Re: front S/S spring hanger mounting holes [Re: jst19600] #289105
04/15/09 03:21 PM
04/15/09 03:21 PM
Steve1118 Offline
Steve1118  Offline
Lowering the front of the spring (further up into the body) will lower the car, and should increase the rise of the springs. Doing that, and then raising the rear of the car should increase the dynamic rise even further.
It is something you have to play with, but most guys I know still running SS springs use the upper hole, and some even stick even another hole further up. Over the years, we've got it to the point that we don't even mess with the lower hole anymore.
You want about three inches of rise with an automatic trans car. That seems to work best for most.
However, like anything else, it is just the playing around until you get it where the car likes.
Re: front S/S spring hanger mounting holes [Re: AndyF] #289106
04/15/09 03:25 PM
04/15/09 03:25 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
How does that change your pinion angle if any using the top hole as compared to the bottom hole?
Re: front S/S spring hanger mounting holes [Re: jst19600] #289107
04/15/09 04:23 PM
04/15/09 04:23 PM
AndyF Offline
AndyF  Offline
Yes, it change the pinion angle a little bit when you move the eye bolt position. You just have to check it and if it isn't in spec then adjust it with some tapered spacers or some other method.
Re: front S/S spring hanger mounting holes [Re: AndyF] #289108
04/15/09 05:11 PM
04/15/09 05:11 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I just put a set under the 65 and used Andys hangers.I still have to drill them as the set the holes back probally 3/4 inch too far for the 65.Not as much as the MP hangers did though.Rocky
Chrysler Firepower
Re: front S/S spring hanger mounting holes [Re: therocks] #289109
04/15/09 08:12 PM
04/15/09 08:12 PM
AndyF Offline
AndyF  Offline
Sounds like you got the wrong part number. There is a Dodge version and a Ply version. AR015 fits the '65 Dodge B body car, AR097 fits the '65 Ply body.
