70 Barracuda Gran Coupe Which Clutch? #2885142
02/07/21 02:54 PM
02/07/21 02:54 PM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
70 Barracuda Gran Coupe 383 4Speed which clutch 10.5 or 10.95 inch. I have the original 513 bellhousing and 130 tooth flywheel but i get conflicting answers looking at clutch kits. Thanks, Lou
Lou P.
Newark DE
Re: 70 Barracuda Gran Coupe Which Clutch? [Re: Dogpro] #2885230
02/07/21 05:47 PM
02/07/21 05:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Original was the 10.95 scallop clutch cover, BorgBeck/3 finger design
Re: 70 Barracuda Gran Coupe Which Clutch? [Re: DAYCLONA] #2885552
02/08/21 02:40 PM
02/08/21 02:40 PM
IMGTX Offline
IMGTX  Offline
Dayclona is correct on the 10.95.
The reason for the confusion you may be finding is that the 10.95 uses the same flywheel as the 10.5". The bolt pattern of the pressure plate is the same but they squeezed in a larger, (almost 11") pressure plate for extra holding power.
As a result a lot of companies and people will sell/use them interchangeably.
Re: 70 Barracuda Gran Coupe Which Clutch? [Re: IMGTX] #2885642
02/08/21 06:49 PM
02/08/21 06:49 PM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
Thanks for both of the replies and explanations up Lou
Lou P.
Newark DE
Re: 70 Barracuda Gran Coupe Which Clutch? [Re: Dogpro] #2885683
02/08/21 10:13 PM
02/08/21 10:13 PM
VA
dragon slayer Offline
VA
The pressure plate is actually 11" same as the 11" clutch. The disc is what is 10.95 to clear the bolts. You also need the special bolts for the scalloped clutch. They provide additional clearance for the disc.
Re: 70 Barracuda Gran Coupe Which Clutch? [Re: dragon slayer] #2890618
02/19/21 04:50 PM
02/19/21 04:50 PM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
I decided to go with a Hayes borg and beck 10.95 and when I got the kit the pressure plate is just under 10.95 inches but the disc is 10.5 inches. Is this right or did they send me the wrong disc? Thanks Lou
Lou P.
Newark DE
Re: 70 Barracuda Gran Coupe Which Clutch? [Re: Dogpro] #2890689
02/19/21 07:45 PM
02/19/21 07:45 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Is that what you ordered? Why not call the vendor if you suspect they sent the wrong item?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 70 Barracuda Gran Coupe Which Clutch? [Re: Dogpro] #2890701
02/19/21 07:57 PM
02/19/21 07:57 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Carefully note that in order for the clutch's warranty to be valid...
U need to either resurface the flywheel or replace it..
Just my $0.02... wink
Re: 70 Barracuda Gran Coupe Which Clutch? [Re: Sinitro] #2890744
02/19/21 09:10 PM
02/19/21 09:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
And most recommend 500 miles of normal driving before Hammering it wink
I would not install it, twocents
beer
Re: 70 Barracuda Gran Coupe Which Clutch? [Re: TJP] #2890905
02/20/21 10:29 AM
02/20/21 10:29 AM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
Lou P.
Newark DE
