Re: is a 10.95 clutch disc actually 10.95 inches?
[Re: dirt]
#1050115
08/09/11 11:01 PM
08/09/11 11:01 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
From their FAQs:
I have a Chrysler application and the pressure plate sizings are confusing. How do I know if I have a 10.5, 10.95, or 11 inch clutch?
Chrysler used several clutch configurations in early model cars, including a special 10.95 clutch which is essentially an 11 inch pressure plate in a 10.5 inch cover. The best way to tell is to fist measure across the bolt circle of the flywheel. The 10.5 and 10.95 inch patterns measure 11.375” center to center across the bolt circle. True 11 inch patterns measure 12.375”. If your bolt circle is 11.375 and the pressure ring measures just under 11 inches across, you have a 10.95 pressure plate. Also note that 10.95 clutch sets utilize a 10.5 inch clutch disc. Finally, if you application uses a 130 tooth flywheel, you must choose between the 10.5 or 10.95 clutches as an 11 inch will not fit the flywheel.
[Re: dirt]
#1050119
08/10/11 09:20 AM
08/10/11 09:20 AM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
thanks, i wonder whats the advantage to a 10.95 clutch if the disc is still only 10.5" ?
There really wouldn't be one, you still have only the 10.5 clutch surface .
[Re: JohnRR]
#1050120
08/10/11 10:01 AM
08/10/11 10:01 AM
Posts: 4,285 Ohio
64dodge572
Ohio
FWIW McLeod 10.95" discs measure around 10 7/8" Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
