70 Barracuda Gran Coupe Which Clutch?
#2885142
02/07/21 02:54 PM
02/07/21 02:54 PM
Posts: 367 Newark DE
Dogpro
Newark DE
70 Barracuda Gran Coupe 383 4Speed which clutch 10.5 or 10.95 inch. I have the original 513 bellhousing and 130 tooth flywheel but i get conflicting answers looking at clutch kits. Thanks, Lou
Lou P. Newark DE
Re: 70 Barracuda Gran Coupe Which Clutch?
[Re: Dogpro]
#2885230
02/07/21 05:47 PM
02/07/21 05:47 PM
Posts: 18,157 Mass
DAYCLONA
Mass
70 Barracuda Gran Coupe 383 4Speed which clutch 10.5 or 10.95 inch. I have the original 513 bellhousing and 130 tooth flywheel but i get conflicting answers looking at clutch kits. Thanks, Lou Original was the 10.95 scallop clutch cover, BorgBeck/3 finger design
[Re: IMGTX]
#2885642
02/08/21 06:49 PM
02/08/21 06:49 PM
Dogpro
Newark DE
Thanks for both of the replies and explanations Lou
Lou P. Newark DE
[Re: dragon slayer]
#2890618
02/19/21 04:50 PM
02/19/21 04:50 PM
Dogpro
Newark DE
I decided to go with a Hayes borg and beck 10.95 and when I got the kit the pressure plate is just under 10.95 inches but the disc is 10.5 inches. Is this right or did they send me the wrong disc? Thanks Lou
Lou P. Newark DE
[Re: Dogpro]
#2890701
02/19/21 07:57 PM
02/19/21 07:57 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Carefully note that in order for the clutch's warranty to be valid... U need to either resurface the flywheel or replace it.. Just my $0.02...
[Re: Sinitro]
#2890744
02/19/21 09:10 PM
02/19/21 09:10 PM
Posts: 15,434 Omaha Ne
TJP
Omaha Ne
Carefully note that in order for the clutch's warranty to be valid... U need to either resurface the flywheel or replace it.. Just my $0.02... And most recommend 500 miles of normal driving before Hammering it I would not install it,
