Re: undrdash a/c whats needed
[Re: Dakota_Don]
#286440
04/13/09 12:08 PM
04/13/09 12:08 PM
no my car didnt come with a/c..
so everything i need will be in the underdash unit. Even the expansionvalve? and if so can i purchace a new valve for the unit?
I've only seen a few---10 or so--hang on units, and had one on my old 70 RR. The dash unit should be pretty much self contained, only needing hoses to the compressor, receiver--dryer and condenser. It's possible on any unit that the TXV might be a proprietary unit and difficult to find a replacement for. Keep in mine that with older units you need to be able to upgrade to modern refrigerants.
(Back "in the day" after a major overhaul, I used engine vacuum!!!! to evacuate the hang on unit and then recharging)
