undrdash a/c whats needed #286434
04/12/09 08:58 PM
04/12/09 08:58 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
HI all what is used for an underdash a/c unit..
reason why i ask is, I am looking at a used underdash unit and I want to make sure i get everthing.
I mostly just want the inside items only..
thanks
Re: undrdash a/c whats needed [Re: Dakota_Don] #286435
04/12/09 09:32 PM
04/12/09 09:32 PM
st. Louis Mo.
dartphil Offline
dartphil  Offline
st. Louis Mo.
Most underdash units are self contained with everything needed. Just run the hoses through the firewall to the engine components.
Re: undrdash a/c whats needed [Re: dartphil] #286436
04/12/09 10:01 PM
04/12/09 10:01 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
There should be an evaporter and fan assembly and the controls.Then just the hoses as stated above.
Re: undrdash a/c whats needed [Re: Dakota_Don] #286437
04/12/09 11:01 PM
04/12/09 11:01 PM
SeventySatellite Offline
Is your car an original A/C car?
Re: undrdash a/c whats needed [Re: SeventySatellite] #286438
04/13/09 11:52 AM
04/13/09 11:52 AM
Alton, IL
Alton, IL
no my car didnt come with a/c..
so everything i need will be in the underdash unit.
Even the expansionvalve? and if so can i purchace a new valve for the unit?
Re: undrdash a/c whats needed [Re: Dakota_Don] #286439
04/13/09 11:59 AM
04/13/09 11:59 AM
Grand Prairie,Texas
Grand Prairie,Texas
What are you planning for the condenser,compressor etc?
Re: undrdash a/c whats needed [Re: Dakota_Don] #286440
04/13/09 12:08 PM
04/13/09 12:08 PM
I've only seen a few---10 or so--hang on units, and had one on my old 70 RR. The dash unit should be pretty much self contained, only needing hoses to the compressor, receiver--dryer and condenser. It's possible on any unit that the TXV might be a proprietary unit and difficult to find a replacement for. Keep in mine that with older units you need to be able to upgrade to modern refrigerants.
(Back "in the day" after a major overhaul, I used engine vacuum!!!! to evacuate the hang on unit and then recharging)
Re: undrdash a/c whats needed [Re: stumpy] #286441
04/13/09 02:58 PM
04/13/09 02:58 PM
Alton, IL
Alton, IL
as far as compressor i want to use a sanden unit..
Re: undrdash a/c whats needed [Re: Dakota_Don] #286442
04/13/09 03:03 PM
04/13/09 03:03 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I just removed this from my 57 Plymouth. Pretty basic setup, AC compressor, engine brackets, condensor, evaporator, rubber lines, and under dash blower/cooler unit. Every single item is shown here. Modern versions are basically the same short of cosmetic differences.
