Re: Hedman 75140 headers
[Re: 412 SB Duster]
#2862914
12/21/20 12:42 PM
12/21/20 12:42 PM
Posts: 1,073 oregon
greendart408
oregon
Anyone have experience using these headers on a set of Indy 360-1's?
Looking for options to put on a stroked small block in a duster to replace a set of TTI's .
Al Yes sir, it's a full 1 tenth and 1.5mph gain over tti's. Did the exact test on a stocker pump gas 408, 10.80 deal, and also on a mid 9.50 deal. Cutt the flanges and they come out of car with everything installed. Way easy to work with. Both combos gained the same by switching. Just my track results, others may vary.
[Re: greendart408]
#2863010
12/21/20 04:25 PM
12/21/20 04:25 PM
Posts: 310 Michigan
412 SB Duster
Al Yes sir, it's a full 1 tenth and 1.5mph gain over tti's. Did the exact test on a stocker pump gas 408, 10.80 deal, and also on a mid 9.50 deal. Cutt the flanges and they come out of car with everything installed. Way easy to work with. Both combos gained the same by switching. Just my track results, others may vary. Thanks for the reply, this is exactly what i was looking for. Any chance you have any engine pics saved with these the hedman's on ? Al
[Re: justinp61]
#2863014
12/21/20 04:32 PM
12/21/20 04:32 PM
Posts: 310 Michigan
412 SB Duster
I have them on my 434", 360-1 headed small block. I too cut the flanges to make installing them easier. That's good to know, Did you see any improvement or was this a new build? Any chance you have some pics? I've been having a hard time finding much online. Al
[Re: justinp61]
#2863310
12/22/20 12:12 PM
12/22/20 12:12 PM
Posts: 310 Michigan
412 SB Duster
I did see those pics during my search, Didn't look like Indy heads when i seen them so I kept looking. i guess i need to look closer next time lol Thanks
[Re: MichaelF]
#2863311
12/22/20 12:14 PM
12/22/20 12:14 PM
Posts: 310 Michigan
412 SB Duster
i ordered a set at summit to swap out with my cheap 1 5/8" headers....should be here tomorrow afternoon. If you have some time i can post some photos during installation (will take at least 2 month, have to do other things before).
Michael
I'm sure i'll be into the install myself by then, but id still like to see the pics. Al
[Re: 412 SB Duster]
#2863410
12/22/20 03:34 PM
12/22/20 03:34 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
Michael
I'm sure i'll be into the install myself by then, but id still like to see the pics. Al i need to install mine
[Re: justinp61]
#2863850
12/23/20 11:40 AM
12/23/20 11:40 AM
Posts: 310 Michigan
412 SB Duster
Guys be aware that some Milodon pans require a bit of surgery when used with the Hedman's.
Would you be able to fit a blanket on it after you clearanced the pan? My plan is to get a uncoated set and do any mods needed to fit a blanket on mine then have them coated. Al
