Holley Sniper on a big block #2860746
12/16/20 01:32 PM
12/16/20 01:32 PM
Az
69hemibeep Offline OP
Az
. Where are you guys putting the sensor for the EFI and still run a gauge
1969 Hemi Roadrunner 2nd owner
Re: Holley Sniper on a big block [Re: 69hemibeep] #2860796
12/16/20 02:28 PM
12/16/20 02:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most (all?) BB water pump housings have an unused coolant port that can be unplugged for a second temp sensor.
Re: Holley Sniper on a big block [Re: John_Kunkel] #2860808
12/16/20 02:38 PM
12/16/20 02:38 PM
Az
Az
After market housing hate to put a T in a heater hose nipple
Re: Holley Sniper on a big block [Re: 69hemibeep] #2860835
12/16/20 03:14 PM
12/16/20 03:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You should be able to drill and tap the housing. Mine from Mancini aftermarket has an extra hole. Others I just do as I said.
Re: Holley Sniper on a big block [Re: NITROUSN] #2860855
12/16/20 03:51 PM
12/16/20 03:51 PM
Az
Az
I have the same housing but if I drill it to size the hole will get into the mounting hole for the housing bolt
Re: Holley Sniper on a big block [Re: 69hemibeep] #2860866
12/16/20 04:00 PM
12/16/20 04:00 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Re: Holley Sniper on a big block [Re: KillerBee] #2860873
12/16/20 04:05 PM
12/16/20 04:05 PM
Az
Az
Nice but it would interfer with my A/C compressor
Re: Holley Sniper on a big block [Re: 69hemibeep] #2860929
12/16/20 05:46 PM
12/16/20 05:46 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Isn't there a pipe plug on the side of the block near a freeze plug?
Re: Holley Sniper on a big block [Re: 69hemibeep] #2860951
12/16/20 06:47 PM
12/16/20 06:47 PM
N
NITROUSN Offline
NITROUSN  Offline
N
This is the housing I have on my Hemi right now from Mancini.
Re: Holley Sniper on a big block [Re: NITROUSN] #2861075
12/16/20 10:51 PM
12/16/20 10:51 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
440 Source pump housing with the Holley temp sensor and an Autometer sensor.
Re: Holley Sniper on a big block [Re: NITROUSN] #2861165
12/17/20 09:39 AM
12/17/20 09:39 AM
Az
Az
Same housing. The two 5/8 holes are heater hose nipples the 1/4 is plugged and the 9/16 has a large mechanical water temp sender in it.
Re: Holley Sniper on a big block [Re: MarkZ] #2861167
12/17/20 09:46 AM
12/17/20 09:46 AM
Az
Az
[quote=MarkZ]440 Source pump housing with the Holley temp sensor and an Autometer sensor. [/quote
] That would work if I change all my gauges to match, I can look into that but I was hoping for an easier less expensive route.
Re: Holley Sniper on a big block [Re: 69hemibeep] #2861274
12/17/20 12:54 PM
12/17/20 12:54 PM
AndyF Offline
AndyF  Offline
Get rid of the mechanical sending unit and gauge. Use the small 1/8 NPT hole for the stock sending unit and the stock gauge in the dash. Use the 3/8 NPT for the Sniper sending unit. You don't need the mechanical gauge anymore since the coolant temp will be on the hand held. The temp gauge in the dash will be your backup.
Re: Holley Sniper on a big block [Re: AndyF] #2861286
12/17/20 01:26 PM
12/17/20 01:26 PM
Az
Az
I found an electric gauge that matches the other gauges (I built them into the dash) with 1/8 sending unit so I'm set. Now I will order the in tank fuel pump kit for the Valiant. I was thinking the jeep would get the Sniper if this didn't pan out. Thanks for the input
Re: Holley Sniper on a big block [Re: 69hemibeep] #2861381
12/17/20 04:27 PM
12/17/20 04:27 PM
AndyF Offline
AndyF  Offline
Yes that will work, or just get rid of the water temp gauge and put a different gauge in there. The handheld display will show you the coolant temp so you don't really need two temp gauges. The hand held also shows you air temp and barometer so it is a built in weather station. If you bought a super sniper then you can see fuel pressure and oil pressure too.
On my car I got rid of the stock dash and installed a Holley Pro Dash.
