Holley Sniper on a big block
#2860746
12/16/20 01:32 PM
12/16/20 01:32 PM
Posts: 1,383 Az
69hemibeep
Az
. Where are you guys putting the sensor for the EFI and still run a gauge
1969 Hemi Roadrunner 2nd owner
Re: Holley Sniper on a big block
[Re: 69hemibeep]
#2860796
12/16/20 02:28 PM
12/16/20 02:28 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Most (all?) BB water pump housings have an unused coolant port that can be unplugged for a second temp sensor.
[Re: John_Kunkel]
#2860808
12/16/20 02:38 PM
12/16/20 02:38 PM
Posts: 1,383 Az
69hemibeep
Az
After market housing hate to put a T in a heater hose nipple
[Re: NITROUSN]
#2860855
12/16/20 03:51 PM
12/16/20 03:51 PM
Posts: 1,383 Az
69hemibeep
Az
You should be able to drill and tap the housing. Mine from Mancini aftermarket has an extra hole. Others I just do as I said. I have the same housing but if I drill it to size the hole will get into the mounting hole for the housing bolt
[Re: KillerBee]
#2860873
12/16/20 04:05 PM
12/16/20 04:05 PM
Posts: 1,383 Az
69hemibeep
Az
Nice but it would interfer with my A/C compressor
[Re: 69hemibeep]
#2860951
12/16/20 06:47 PM
12/16/20 06:47 PM
Posts: 18,415 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
You should be able to drill and tap the housing. Mine from Mancini aftermarket has an extra hole. Others I just do as I said. I have the same housing but if I drill it to size the hole will get into the mounting hole for the housing bolt This is the housing I have on my Hemi right now from Mancini.
[Re: NITROUSN]
#2861075
12/16/20 10:51 PM
12/16/20 10:51 PM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
440 Source pump housing with the Holley temp sensor and an Autometer sensor.
[Re: NITROUSN]
#2861165
12/17/20 09:39 AM
12/17/20 09:39 AM
Posts: 1,383 Az
69hemibeep
Az
You should be able to drill and tap the housing. Mine from Mancini aftermarket has an extra hole. Others I just do as I said. I have the same housing but if I drill it to size the hole will get into the mounting hole for the housing bolt This is the housing I have on my Hemi right now from Mancini. Same housing. The two 5/8 holes are heater hose nipples the 1/4 is plugged and the 9/16 has a large mechanical water temp sender in it.
[Re: MarkZ]
#2861167
12/17/20 09:46 AM
12/17/20 09:46 AM
Posts: 1,383 Az
69hemibeep
Az
[quote=MarkZ]440 Source pump housing with the Holley temp sensor and an Autometer sensor. [/quote ] That would work if I change all my gauges to match, I can look into that but I was hoping for an easier less expensive route.
[Re: AndyF]
#2861286
12/17/20 01:26 PM
12/17/20 01:26 PM
Posts: 1,383 Az
69hemibeep
Az
I found an electric gauge that matches the other gauges (I built them into the dash) with 1/8 sending unit so I'm set. Now I will order the in tank fuel pump kit for the Valiant. I was thinking the jeep would get the Sniper if this didn't pan out. Thanks for the input
