Originally Posted by NITROUSN
You should be able to drill and tap the housing. Mine from Mancini aftermarket has an extra hole. Others I just do as I said.
I have the same housing but if I drill it to size the hole will get into the mounting hole for the housing bolt
This is the housing I have on my Hemi right now from Mancini.
Same housing. The two 5/8 holes are heater hose nipples the 1/4 is plugged and the 9/16 has a large mechanical water temp sender in it.
1969 Hemi Roadrunner 2nd owner
