HELP!! A-Body wiper nightmare!!! #285149
04/11/09 09:35 PM
04/11/09 09:35 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Help! I am going nuts trying to find the right part to get the wipers to work on my 1970 Dodge Dart. There is some sort of bushing or retainer that is supposed to connect the wiper linkage to the motor drive arm, but I cannot seem to locate the right part. I have bought 2 different bushings already but neither is even close. Near as I can tell the drive arm is about 3/8" diameter and the whole in the linkage is 3/4" or bigger. Does anyone know what piece I need?!? I'm going to post some photos.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: HELP!! A-Body wiper nightmare!!! [Re: MadMatt] #285150
04/11/09 09:36 PM
04/11/09 09:36 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Here's the linkage...
Re: HELP!! A-Body wiper nightmare!!! [Re: MadMatt] #285151
04/11/09 09:37 PM
04/11/09 09:37 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
And the bushings that don't work...
Re: HELP!! A-Body wiper nightmare!!! [Re: MadMatt] #285152
04/11/09 09:45 PM
04/11/09 09:45 PM
MNobody Offline
MNobody  Offline
I found a bushing that worked for my 68 in the Help section at the local auto part's store.
Re: HELP!! A-Body wiper nightmare!!! [Re: MNobody] #285153
04/11/09 10:14 PM
04/11/09 10:14 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
This one's from a '68 B-body, but I think the A-body part is the same or very similar.
Re: HELP!! A-Body wiper nightmare!!! [Re: In_The_Pink] #285154
04/11/09 10:46 PM
04/11/09 10:46 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Pretty much the same as the above picture, but there is a sheetmetal washer and spring clip that you need that I show in the picture. The washer goes through the pin, then the black plastic bushing, then the spring clip holds washer and bushing on the pin by slipping it over the pin to where the clamp captures the end of the pin.
JB Rhinehart, Realist
A-Body's RULE!
Re: HELP!! A-Body wiper nightmare!!! [Re: Rhinodart] #285155
04/12/09 12:07 AM
04/12/09 12:07 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
That looks right! I think I have the spring clip and I can find a washer. Any idea where I can get the bushing??
Re: HELP!! A-Body wiper nightmare!!! [Re: MadMatt] #285156
04/12/09 01:36 AM
04/12/09 01:36 AM
Texas
TexasStroker Offline
mopar addict
mopar addict
Texas
As mentioned, your easiest and most affordable way to get the bushing is to find an auto parts store that has a "Help" section and buy the wiper arm linkage bushing pack (something like 6-12 in it) and of course, there will only be 2 Chryslers n the pack
I had to pick some up for the Duster and just got 2 of the packs and used what I could, don't know what happened to the rest of them...oh well.
You aren't looking at over $10 to get what you need...
For the record mine were found at AutoZone. I'm sure someone repops them, but by the time you pay freight you'd come out on the high side of the deal.
Founder, Amarillo Area Mopars & Lone Star Mopars Amarillo Area Mopars Lone Star Mopars Chryslers in the Canyon: All Mopar Event!
Re: HELP!! A-Body wiper nightmare!!! [Re: TexasStroker] #285157
04/12/09 10:47 AM
04/12/09 10:47 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Re: HELP!! A-Body wiper nightmare!!! [Re: Rug_Trucker] #285158
04/12/09 01:59 PM
04/12/09 01:59 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Another possibility - you're only 55 miles from Spring Fling, which is in two weeks. Lots of the vendors there have many of the odd or unusual parts you may not find anywhere else. May be worth a shot.
Re: HELP!! A-Body wiper nightmare!!! [Re: Fab64] #285159
04/12/09 04:23 PM
04/12/09 04:23 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Is it a 2 speed or variable speed wiper motor? I looked in the 70 parts book and I believe the part number you need is 2580200 or 2631766 depending on which motor you have. Valley Vintage Auto Parts has the 2580200. Give them a call and maybe they can email you a pic of it to make sure it is the one you need. Phone# 440-355-4085
Re: HELP!! A-Body wiper nightmare!!! [Re: mopars4ever] #285160
04/12/09 04:38 PM
04/12/09 04:38 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Can you provide the wiper link arm's hole diameter? And the part number stamped into the pitman arm?
I have these pieces I can send you if they are what you need:
Re: HELP!! A-Body wiper nightmare!!! [Re: In_The_Pink] #285161
04/12/09 06:56 PM
04/12/09 06:56 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Near as I can tell (it's TOUGH getting my hand in there) the hole measures 3/4" diameter.
By the way, just got back from Pep Boys and they have about 6 different packages of wiper bushings, but none of them looked even close to what I need.
Re: HELP!! A-Body wiper nightmare!!! [Re: MadMatt] #285162
04/12/09 06:59 PM
04/12/09 06:59 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I probably have 2 dozen of the correct parts. As seen in the picture I provided above, those parts were just laying around in a pan full of A-body only wiper parts. I have parted out over 300 Darts of all years in the last 30 years. If you can wait until Spring Fling, I can bring you a set you can have, and I can even help you install them!
A-Body's RULE!
Re: HELP!! A-Body wiper nightmare!!! [Re: Rhinodart] #285163
04/12/09 08:10 PM
04/12/09 08:10 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I sure appreciate the offer, but I am actually trying to get the dash project done in time to take the car to the Fling. Or at least the Mopar cruise at California Car Cover on Saturday night if I have to thrash that Saturday day to finish it.
Any chance I could send you a couple of bucks and a SASE and get you to mail the bushing to me?
Re: HELP!! A-Body wiper nightmare!!! [Re: MadMatt] #285164
04/12/09 08:35 PM
04/12/09 08:35 PM
this is how
Re: HELP!! A-Body wiper nightmare!!! #285165
04/12/09 08:36 PM
04/12/09 08:36 PM
Re: HELP!! A-Body wiper nightmare!!! #285166
04/12/09 08:48 PM
04/12/09 08:48 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
right clik save, right clik save
as to the orig poster, wipers 2 or 3 spd ?
Re: HELP!! A-Body wiper nightmare!!! #285167
04/12/09 08:54 PM
04/12/09 08:54 PM
2 spd bushing vs 3 spd bushing
left one is 2 speed
Re: HELP!! A-Body wiper nightmare!!! #285168
04/12/09 08:54 PM
04/12/09 08:54 PM
other side
