Doms T rams carbs out of the box dyno'd #2849242
11/20/20 08:49 PM
11/20/20 08:49 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Well i didn't make it to the track this fall with the new tunnel ram set up, but will come spring. I need new tires before i go and i spent enough money this year. I did get it on a chassis dyno today thou. Doms carbs have a very flat curve. Just going up 2 sizes on HSB gained 60hp. Had a 30 in it and went up with a 32. Nice gain. Tried several other thing like removing velocity stacks with screen filter and gain 6hp/4tq. The screens are that restrictive. The data at the bottom of the pages don't match up to whats on the graph. Can't explain that. Looks like 519hp/561TQ at the wheel. The guys at the shop were very impressed with Doms carbs snappyness.
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849246
11/20/20 08:54 PM
11/20/20 08:54 PM
Mt Morris Michigan
Mt Morris Michigan
I was very surprised to find peak hp at 6000rpm and peak torque 4600rpm. I thinks its time to ditch the flat tappet and get a big roller in it. Would like to see the peak power at 6500 at least.
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849249
11/20/20 08:57 PM
11/20/20 08:57 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Looks like the air was Real good, the correction took Hp away, did you get a uncorrected # also
Re: Doms T rams carbs out of the box dyno'd [Re: CSK] #2849250
11/20/20 08:59 PM
11/20/20 08:59 PM
Mt Morris Michigan
Mt Morris Michigan
I don't think so. Humidity 40%, good air. First run it just about jumped off the dyno, had to strap better and then next it crashed the computer. After some time they got things up and running again.
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849252
11/20/20 09:06 PM
11/20/20 09:06 PM
Mt Morris Michigan
Mt Morris Michigan
Check out the crank values. Not sure how accurate these are.
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849253
11/20/20 09:08 PM
11/20/20 09:08 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Correction factor .998
Re: Doms T rams carbs out of the box dyno'd [Re: CSK] #2849258
11/20/20 09:20 PM
11/20/20 09:20 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, i don't know how to use the correction number. What does that tell you?
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849263
11/20/20 09:29 PM
11/20/20 09:29 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
It made at the time more HP than what is printed out, not much, but a little.it made 499.5 without correction for the weather & corrected 498.8 , no big deal just an observation
Re: Doms T rams carbs out of the box dyno'd [Re: CSK] #2849269
11/20/20 09:37 PM
11/20/20 09:37 PM
Mt Morris Michigan
Mt Morris Michigan
Not sure how they get 730 out of 520? My moroso slide rule says 675 with a Dominator. Here's a vid. https://youtu.be/qq5b9mIvJMU
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849377
11/21/20 03:52 AM
11/21/20 03:52 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Their crank values to wheel values are absurd, that would be generating a massive amount of heat to have that kind of loss..
Re: Doms T rams carbs out of the box dyno'd [Re: Uberpube] #2849414
11/21/20 09:13 AM
11/21/20 09:13 AM
Mt Morris Michigan
Mt Morris Michigan
That was my point. I can also say Mustang dyno's sap a lot of power from your rear wheel number, but that was not the reason for going. I just needed the peak rpm numbers and the fuel curve data and i am happy with that. I just looked at my Moroso slide calculator and using mph and weight it gives 630hp using my single 1100 dominator. So with tunnel ram i would think 660-680 crank hp would be more accurate, but who knows.
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849451
11/21/20 10:51 AM
11/21/20 10:51 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Chassis dyno power curves, especially those that are derived from a combo with a loose converter won’t look anything like what the curve would look like from an engine dyno.
Unless something very very odd is going on with that combo, there is no way the engine TQ numbers will be higher than the HP numbers on your build.
Quote
Especially the TQ value.
Re: Doms T rams carbs out of the box dyno'd [Re: fast68plymouth] #2849482
11/21/20 11:41 AM
11/21/20 11:41 AM
Mt Morris Michigan
Mt Morris Michigan
Didn't know that, but wouldn't this curve look the same as the car go's down the track?
Re: Doms T rams carbs out of the box dyno'd [Re: fast68plymouth] #2849484
11/21/20 11:42 AM
11/21/20 11:42 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Mustang Dyno's always do that.....lol
Re: Doms T rams carbs out of the box dyno'd [Re: Dragula] #2849488
11/21/20 11:57 AM
11/21/20 11:57 AM
Mt Morris Michigan
Mt Morris Michigan
The last time i was on a Mustang dyno, it had me down 200hp. I had a small block then. The dyno run yesterday did show where my peaks are and i don't like where their at. Also Dom's carbs flat fuel curve after peak tq.
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849557
11/21/20 01:48 PM
11/21/20 01:48 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I used to work in a shop with a Dynojet wheel dyno. With an auto and loose converter numbers would be all over the place. We did a S/C small block Vette that made 414 on the dyno, but ran 8:6X@153.
Re: Doms T rams carbs out of the box dyno'd [Re: slantzilla] #2849633
11/21/20 04:41 PM
11/21/20 04:41 PM
Mt Morris Michigan
Mt Morris Michigan
Thats what i'm talkin about. I do think the Dynojets are more accurate than the Mustang thou if your looking at hp/tq numbers. The graphs off the dynojet are better laid out as well.
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849645
11/21/20 05:07 PM
11/21/20 05:07 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You can't really look at them as accurate IMO. You just have to look at it as a number, if you leave there and that number, whatever it is, is higher than when you got there you made an improvement. That being the case you also need to stick to one dyno and operator to be able to do comparisons on each trip.
68 Barracuda Formula S 340
Re: Doms T rams carbs out of the box dyno'd [Re: Bad340fish] #2849646
11/21/20 05:12 PM
11/21/20 05:12 PM
Mt Morris Michigan
Mt Morris Michigan
I agree. The are a tool.
Re: Doms T rams carbs out of the box dyno'd [Re: mopar dave] #2849660
11/21/20 06:21 PM
11/21/20 06:21 PM
Dragula Offline
Dragula  Offline
And this is why I don't dyno my chit.....
