Re: Doms T rams carbs out of the box dyno'd
[Re: mopar dave]
#2849249
11/20/20 08:57 PM
11/20/20 08:57 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
Looks like the air was Real good, the correction took Hp away, did you get a uncorrected # also
[Re: CSK]
#2849250
11/20/20 08:59 PM
11/20/20 08:59 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I don't think so. Humidity 40%, good air. First run it just about jumped off the dyno, had to strap better and then next it crashed the computer. After some time they got things up and running again.
[Re: mopar dave]
#2849263
11/20/20 09:29 PM
11/20/20 09:29 PM
CSK
Pattison Texas
It made at the time more HP than what is printed out, not much, but a little.it made 499.5 without correction for the weather & corrected 498.8 , no big deal just an observation
[Re: Uberpube]
#2849414
11/21/20 09:13 AM
11/21/20 09:13 AM
mopar dave
Mt Morris Michigan
That was my point. I can also say Mustang dyno's sap a lot of power from your rear wheel number, but that was not the reason for going. I just needed the peak rpm numbers and the fuel curve data and i am happy with that. I just looked at my Moroso slide calculator and using mph and weight it gives 630hp using my single 1100 dominator. So with tunnel ram i would think 660-680 crank hp would be more accurate, but who knows.
[Re: mopar dave]
#2849451
11/21/20 10:51 AM
11/21/20 10:51 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Chassis dyno power curves, especially those that are derived from a combo with a loose converter won’t look anything like what the curve would look like from an engine dyno. Unless something very very odd is going on with that combo, there is no way the engine TQ numbers will be higher than the HP numbers on your build. Their crank values to wheel values are absurd Especially the TQ value.
[Re: mopar dave]
#2849557
11/21/20 01:48 PM
11/21/20 01:48 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
I used to work in a shop with a Dynojet wheel dyno. With an auto and loose converter numbers would be all over the place. We did a S/C small block Vette that made 414 on the dyno, but ran 8:6X@153.
[Re: mopar dave]
#2849645
11/21/20 05:07 PM
11/21/20 05:07 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
You can't really look at them as accurate IMO. You just have to look at it as a number, if you leave there and that number, whatever it is, is higher than when you got there you made an improvement. That being the case you also need to stick to one dyno and operator to be able to do comparisons on each trip.
68 Barracuda Formula S 340
