5 SPEEDS IN DAKOTAS #284788
04/11/09 02:59 PM
04/11/09 02:59 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Wondering, what year's Dakota's 5 speeds interchange (V6 models, I have a 97, know of an 88 I can pick up cheap), and also, wondering how hard it would be to put a higher 5th(or maybe an OD range) gear?
Anyone tried this?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 5 SPEEDS IN DAKOTAS [Re: Magnumguy] #284789
04/11/09 05:55 PM
04/11/09 05:55 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
All the 5 spds have an OD 5th gear, it is a .71 ratio.
They are all interchangable depending on what you want to swap with it.
Re: 5 SPEEDS IN DAKOTAS [Re: HotRodDave] #284790
04/11/09 09:45 PM
04/11/09 09:45 PM
S.E.Ohio
S.E.Ohio
Hmm, my 97 doesn't seem to drop off too much when I'm in 5th. It's not marked as "OD".
Perhaps it is.....
Re: 5 SPEEDS IN DAKOTAS [Re: HotRodDave] #284791
04/11/09 09:54 PM
04/11/09 09:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
umm nope. V8 and V6 are different transmissons
and they are not overdrive's just 5th gear
Re: 5 SPEEDS IN DAKOTAS [Re: Mr.Yuck] #284792
04/11/09 10:13 PM
04/11/09 10:13 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Nope. as was posted previously, all 5 speeds in Dakotas would be OD 5th. Probably an AX 15 that year. The New Process A 535 used in '87-89s (maybe a bit longer in years) was not very strong. the AX 15 isn't that great either, but is better. but both are OD in 5th!
Re: 5 SPEEDS IN DAKOTAS [Re: volaredon] #284793
04/11/09 10:15 PM
04/11/09 10:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my 5th gear doesn't seem to be OD. it doesn't coast like a typical OD unit. 95 5.2 5 speed
Coming soon!!!!
Re: 5 SPEEDS IN DAKOTAS [Re: Mr.Yuck] #284794
04/12/09 01:51 AM
04/12/09 01:51 AM
Missouri
NFURY8 Offline
super street
NFURY8  Offline
super street
Missouri
I have a 97 V6 5 spd also, as mentioned the 5th gear is an OD.
According to Allpar the V6 used a AS 82 transmission, 4th gear is 1:1 and 5th is .79 OD.
However, Most other reading would lead to believe it is an AX15. Definitely not the NV3500, which has the bell housing cast in smooth with the case, and appears to be V-8 only.
C-Body DryDock Bigger is Better!
