5 SPEEDS IN DAKOTAS
#284788
04/11/09 02:59 PM
04/11/09 02:59 PM
Posts: 10,645 S.E.Ohio
Magnumguy
S.E.Ohio
Wondering, what year's Dakota's 5 speeds interchange (V6 models, I have a 97, know of an 88 I can pick up cheap), and also, wondering how hard it would be to put a higher 5th(or maybe an OD range) gear?
Anyone tried this?
Re: 5 SPEEDS IN DAKOTAS
[Re: Magnumguy]
#284789
04/11/09 05:55 PM
04/11/09 05:55 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
All the 5 spds have an OD 5th gear, it is a .71 ratio.
They are all interchangable depending on what you want to swap with it.
[Re: HotRodDave]
#284791
04/11/09 09:54 PM
04/11/09 09:54 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
umm nope. V8 and V6 are different transmissons
and they are not overdrive's just 5th gear
[Re: Mr.Yuck]
#284792
04/11/09 10:13 PM
04/11/09 10:13 PM
Posts: 2,251 ILLINOIS
volaredon
ILLINOIS
Nope. as was posted previously, all 5 speeds in Dakotas would be OD 5th. Probably an AX 15 that year. The New Process A 535 used in '87-89s (maybe a bit longer in years) was not very strong. the AX 15 isn't that great either, but is better. but both are OD in 5th!
