Trick Flow heads for early 340 #2820115
09/12/20 11:43 PM
09/12/20 11:43 PM
Australia
fullonmopar Offline OP
Australia
I would love a set of Trick Flow heads for my early 340 down under, my question is, due to the positive deck height of the factory pistons the TF heads being closed chamber would have issues of clearance fitting. Any hints on what to do being short of new pistons with zero or less deck height or maybe slightly machine the heart shaped combustion chambers for clearance on the TF heads. Thank You.
Re: Trick Flow heads for early 340 [Re: fullonmopar] #2820130
09/13/20 01:59 AM
09/13/20 01:59 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Cometic Thicker head gasket
Re: Trick Flow heads for early 340 [Re: CSK] #2820131
09/13/20 02:22 AM
09/13/20 02:22 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
We used to cut the Eddies with a relief cut on the chambers all the time to fit the early 340 pistons. Or order some Cometics any thickness you want up to .120 thick/
Todd
Re: Trick Flow heads for early 340 [Re: fullonmopar] #2820269
09/13/20 04:14 PM
09/13/20 04:14 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
As mentioned, thicker head gasket. I'm going through this now with another brand of closed chamber aluminum heads. My pistons are up to .030" above deck when rocked. Measure on the outside edge of the piston to get the worst case height above deck. Not sure if the block was decked in the past or not. Be that as it may, I'm going to need a .065-.070" gasket unless I do something to address it. A custom gasket set is a lot cheaper than other potential solutions.
Re: Trick Flow heads for early 340 [Re: gzig5] #2820379
09/13/20 08:23 PM
09/13/20 08:23 PM
Australia
Australia
My thinking is it would be better to machine the heads rather than thicker gasket so maybe you can work out your quench a lot better and you wont lose as much overall compression. Maybe using thicker head gaskets will possibly affect the sealing of the manifold gaskets. Also do you have to use a dedicated Trick Flow intake manifold or would for example an Air Gap of Strip Dominator fit as well. We pay double the price for parts from the USA in Australia so I am trying to find the cheapest way out of this, thanks for all you feed back.
Re: Trick Flow heads for early 340 [Re: fullonmopar] #2820405
09/13/20 09:10 PM
09/13/20 09:10 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The Trickflow intakes haven't been released yet.
Any standard style intake should fit
Alan Jones
Re: Trick Flow heads for early 340 [Re: LA360] #2820439
09/13/20 10:47 PM
09/13/20 10:47 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Professional Products make an RPM knock off that looks like a RPM air gap. Todd
Re: Trick Flow heads for early 340 [Re: fullonmopar] #2820545
09/14/20 10:47 AM
09/14/20 10:47 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Get a quote for opening up the chambers on the heads to clear the pistons and get back to us. That's going to cost a lot where a set of gaskets is a couple hundred.
One potential solution would be trimming the compression height on the pistons but you need to be aware of how thick they are and balance issues. All that is going to cost more than gaskets too unless you are doing the machining yourself.
Re: Trick Flow heads for early 340 [Re: gzig5] #2820821
09/14/20 09:33 PM
09/14/20 09:33 PM
Australia
Australia
The gaskets cost $450 down under and I have a friend who can machine the heads, he has done a few Eddy heads before so no problems.
ARP Fastners do not list head studs for the Trick Flows yet so I was wondering if the Eddy head studs Number 144-4005 will fit, if so it would be a bonus as I have a set in stock, I haven't got the heads yet to check, thanks again.
Re: Trick Flow heads for early 340 [Re: fullonmopar] #2820841
09/14/20 10:10 PM
09/14/20 10:10 PM
LA360 Offline
LA360  Offline
Alan Jones
Re: Trick Flow heads for early 340 [Re: LA360] #2821142
09/15/20 03:13 PM
09/15/20 03:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
The current money exchange rate must be bad now work Or someone in that business is trying to get rich quick whistling work
Any one know what it is now?
Re: Trick Flow heads for early 340 [Re: Cab_Burge] #2821260
09/15/20 08:11 PM
09/15/20 08:11 PM
LA360 Offline
LA360  Offline
As of today, the Australian dollar is buying 73 US cents. It has been as low as 65 US cents recently. The lowest I've seen it go in the last 12 months was around 60 US cents. During the GFC the Aussie dollow was worth $0.95 - 1.05
Alan Jones
Re: Trick Flow heads for early 340 [Re: LA360] #2821746
09/16/20 11:11 PM
09/16/20 11:11 PM
Thanks for sharing that information up
Re: Trick Flow heads for early 340 [Re: LA360] #2821777
09/17/20 03:06 AM
09/17/20 03:06 AM
Australia
Australia
The other major facture in the price of the gaskets and parts in general down under is the cost of freight it cost twice as much now compared to a few years ago to ship items from the US.
