Re: Trick Flow heads for early 340
[Re: fullonmopar]
#2820130
09/13/20 01:59 AM
09/13/20 01:59 AM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Cometic Thicker head gasket
[Re: gzig5]
#2820379
09/13/20 08:23 PM
09/13/20 08:23 PM
Posts: 421 Australia
fullonmopar
Australia
My thinking is it would be better to machine the heads rather than thicker gasket so maybe you can work out your quench a lot better and you wont lose as much overall compression. Maybe using thicker head gaskets will possibly affect the sealing of the manifold gaskets. Also do you have to use a dedicated Trick Flow intake manifold or would for example an Air Gap of Strip Dominator fit as well. We pay double the price for parts from the USA in Australia so I am trying to find the cheapest way out of this, thanks for all you feed back.
[Re: fullonmopar]
#2820545
09/14/20 10:47 AM
09/14/20 10:47 AM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
My thinking is it would be better to machine the heads rather than thicker gasket so maybe you can work out your quench a lot better and you wont lose as much overall compression. Maybe using thicker head gaskets will possibly affect the sealing of the manifold gaskets. Also do you have to use a dedicated Trick Flow intake manifold or would for example an Air Gap of Strip Dominator fit as well. We pay double the price for parts from the USA in Australia so I am trying to find the cheapest way out of this, thanks for all you feed back. Get a quote for opening up the chambers on the heads to clear the pistons and get back to us. That's going to cost a lot where a set of gaskets is a couple hundred. One potential solution would be trimming the compression height on the pistons but you need to be aware of how thick they are and balance issues. All that is going to cost more than gaskets too unless you are doing the machining yourself.
[Re: LA360]
#2821142
09/15/20 03:13 PM
09/15/20 03:13 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
The current money exchange rate must be bad now Or someone in that business is trying to get rich quick Any one know what it is now?
[Re: Cab_Burge]
#2821260
09/15/20 08:11 PM
09/15/20 08:11 PM
Posts: 6,145 Melbourne , Australia
LA360
The current money exchange rate must be bad now Or someone in that business is trying to get rich quick Any one know what it is now? As of today, the Australian dollar is buying 73 US cents. It has been as low as 65 US cents recently. The lowest I've seen it go in the last 12 months was around 60 US cents. During the GFC the Aussie dollow was worth $0.95 - 1.05
Alan Jones
