Page 3 of 3 1 2 3
Re: Tools for cutting fiberglass. [Re: mopar dave] #2815323
08/31/20 05:15 AM
08/31/20 05:15 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Looks good up
Re: Tools for cutting fiberglass. [Re: Tig] #2815342
08/31/20 07:42 AM
08/31/20 07:42 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Thanks Tig. The hole ended up a little larger than planned as i had some sanding to fix a couple screw ups. The die grinder did a very nice job cutting a straight line. Just need to fill the hollow support, sand and paint.
Re: Tools for cutting fiberglass. [Re: mopar dave] #2815347
08/31/20 07:52 AM
08/31/20 07:52 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Same here, had to make it easier to take on and off. Also on mine, the centre ridge and engine offset really bugs my symmetry OCD laugh
Re: Tools for cutting fiberglass. [Re: Tig] #2815348
08/31/20 07:56 AM
08/31/20 07:56 AM
Mt Morris Michigan
Mt Morris Michigan
Yes, i do not like the look of the off set of the hole and carbs to the passenger side. I tried to figure how to make that look better by cutting more toward the drivers side, but that just created issues with the gap being larger on one side of the carbs than the other, so i just cut it the fit the carbs.
Re: Tools for cutting fiberglass. [Re: dOoC] #2815568
08/31/20 03:33 PM
08/31/20 03:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by Doc Fiberglass
Damn ccj ... you sound VERY WELL VERSED...
I coulda used a apimp like you some years back ....
But da BOSS would have hammer yur azz over yer politics tsk grin
work Thanks maybe?
It's good to be the boss, laugh2
And OP up
Re: Tools for cutting fiberglass. [Re: mopar dave] #2815617
08/31/20 06:13 PM
08/31/20 06:13 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Nice job!Looks really good.
Re: Tools for cutting fiberglass. [Re: Clanton] #2815714
08/31/20 11:27 PM
08/31/20 11:27 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks Clanton, cant wait til its painted for the big revell.
Re: Tools for cutting fiberglass. [Re: mopar dave] #2815772
09/01/20 08:59 AM
09/01/20 08:59 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
How did the brace turn out?I have a bolt on glass hood and after 15yrs it cracked by the hinge that I need to get to.I would like to fill the inside with something to make it stronger.
Re: Tools for cutting fiberglass. [Re: Clanton] #2815788
09/01/20 09:28 AM
09/01/20 09:28 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The self expanding urethane foam is likely the first/easiest choice. But be warned, over filling can wreak havoc, and/or distort the outer surface. Allowing a few vent holes, can reduce that problem, but the the vent holes if left in place, weaken the item you are trying to reinforce.
Re: Tools for cutting fiberglass. [Re: CMcAllister] #2815874
09/01/20 02:05 PM
09/01/20 02:05 PM
AEFEF
singhharry12 Offline
AEFEF
I do have a zig saw and a roto zip. The hole will be rectangular. Some good info here I will have to digest. Fine blade to prevent chips I assume? 9apps cartoonhd
Re: Tools for cutting fiberglass. [Re: Clanton] #2816005
09/01/20 08:58 PM
09/01/20 08:58 PM
Mt Morris Michigan
Mt Morris Michigan
I have not finished it yet. Does duraglass and tiger hair expand? If not I will fill the openings in the brace and sand. Gonna paint the hood black, but what shade of black should I paint it? I was thinking satin black or something similar.
Page 3 of 3 1 2 3
