Cold rocker clearance #2794161
07/08/20 02:51 AM
07/08/20 02:51 AM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Hi Gents
Have a SBM, has roller lifters, HS 1.6 roller rockers, heads are closed chamber W2 race heads. The cam card says for 1.5 rockers to set the clearance at 0.020” hot, what’s recommended for 1.6 rockers cold please
Re: Cold rocker clearance [Re: crash520] #2794169
07/08/20 05:03 AM
07/08/20 05:03 AM
Guitar Jones Offline
The clearance spec doesn't change. The thing to do is adjust a pair hot to the spec then let it sit overnight and check what the clearance is cold then set the rest to that.
Re: Cold rocker clearance [Re: crash520] #2794181
07/08/20 07:43 AM
07/08/20 07:43 AM
E
earlymopar Offline
earlymopar  Offline
E
I always add .002 - 003" to the hot spec for setting them cold. If you have aluminum heads, I'd use .003"-.004".
- EM
Re: Cold rocker clearance [Re: crash520] #2794185
07/08/20 08:24 AM
07/08/20 08:24 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Lash those at .014" cold and you will be very close when hot. As the engine heats up, everything grows and it opens the lash a bit. I assume those are cast iron w2's?
Re: Cold rocker clearance [Re: crash520] #2794239
07/08/20 10:21 AM
07/08/20 10:21 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted by crash520
Hi Gents
divide .020" by 1.5 and that's the clearance at the tappet; .0133". multiply .0133 by 1.6 and use that number for lash clearance to maintain the same ramp clearance that the 1.5 setting had; which would be .0213".
Re: Cold rocker clearance [Re: lewtot184] #2794433
07/08/20 06:08 PM
07/08/20 06:08 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Thanks gents, yes cast iron W2 heads, I will do the lash hot for sure, just needed a bit of a starting point to set them up cold for the first time
Re: Cold rocker clearance [Re: crash520] #2794444
07/08/20 06:22 PM
07/08/20 06:22 PM
Crane cams use to have a cold lash chart in one of their older catalogs, they recommended adding .002 to the lash at room temps with iron heads and iron blocks, they also recommended using .006 tighter with aluminum heads on a iron block and using .012 tighter with aluminum heads on a aluminum block, that has worked well for me for a lot of years up
Re: Cold rocker clearance [Re: Cab_Burge] #2794552
07/09/20 02:17 AM
07/09/20 02:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats how I do mine as they call for .020 and I set them at .014 cold with my iron block and aluminum heads. Works great for me. Ron
Re: Cold rocker clearance [Re: lewtot184] #2794594
07/09/20 06:15 AM
07/09/20 06:15 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Hi Gents
This is correct, as well as what Cab states about expansion for iron and aluminum heads. So it's a 2 part answer factoring both the change in rocker ratio, and expansion, if you are trying to hit the cam card exactly.
Re: Cold rocker clearance [Re: BSB67] #2794627
07/09/20 09:23 AM
07/09/20 09:23 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
For shaft mopars it also depends on the method used to set the lash.
I set the lash on the Intake side when the Intake is closed and the Exhaust is at max lift and vice versus.
VS
Setting lash when both Intake and Exhaust are closed
Ambient temp makes a difference; this weekend it was 112 in the trailer when I unloaded the car and set the lash - so I set it at .019 rather than .020.
If it had been 30 degrees then I probably would have set it at .017.
I think its all minuscule differences though at my level and more important to know where you set it last time so you can tell if things change.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Cold rocker clearance [Re: 69dart] #2796056
07/13/20 08:08 AM
07/13/20 08:08 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I agree, i think its small peanuts. I tried those lash loops at the track when i had a 408 small block. Didn't see much if any gains with different small lash settings. I had open chamber w2's on it at one time and i do not remember the lash closing up with heat. The math that is suggested to get where you should be with your lash settings looks like the best advice here.
Re: Cold rocker clearance [Re: mopar dave] #2796132
07/13/20 12:00 PM
07/13/20 12:00 PM
Iron block with iron heads and steel pushrods doesn't change the lash much from hot to cold, maybe .001 to .003 shruggy
Re: Cold rocker clearance [Re: mopar dave] #2796137
07/13/20 12:07 PM
07/13/20 12:07 PM
gregsdart Offline
gregsdart  Offline
I had great results changing lash, but i had some serious head and cam limitations. Iron 906 heads,535 cubes, and a .590 solid cam. That motor was desperate for air! With lash spec of .028 i had room, and .014 intake and .012 exhaust lash really helped! BUT- it was the dual problem of very poor heads and small cam that made those settings produce big gains. W2 heads with a cam that is well matched would be hard pressed to see any change at the track. A dyno session would be needed to see small changes.
