Re: Cold rocker clearance
[Re: crash520]
#2794169
07/08/20 05:03 AM
07/08/20 05:03 AM
Guitar Jones
The clearance spec doesn't change. The thing to do is adjust a pair hot to the spec then let it sit overnight and check what the clearance is cold then set the rest to that.
[Re: crash520]
#2794239
07/08/20 10:21 AM
07/08/20 10:21 AM
Posts: 3,916 usa
lewtot184
usa
Hi Gents Have a SBM, has roller lifters, HS 1.6 roller rockers, heads are closed chamber W2 race heads. The cam card says for 1.5 rockers to set the clearance at 0.020” hot, what’s recommended for 1.6 rockers cold please divide .020" by 1.5 and that's the clearance at the tappet; .0133". multiply .0133 by 1.6 and use that number for lash clearance to maintain the same ramp clearance that the 1.5 setting had; which would be .0213".
[Re: Cab_Burge]
#2794552
07/09/20 02:17 AM
07/09/20 02:17 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Crane cams use to have a cold lash chart in one of their older catalogs, they recommended adding .002 to the lash at room temps with iron heads and iron blocks, they also recommended using .006 tighter with aluminum heads on a iron block and using .012 tighter with aluminum heads on a aluminum block, that has worked well for me for a lot of years Thats how I do mine as they call for .020 and I set them at .014 cold with my iron block and aluminum heads. Works great for me. Ron
[Re: lewtot184]
#2794594
07/09/20 06:15 AM
07/09/20 06:15 AM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Hi Gents Have a SBM, has roller lifters, HS 1.6 roller rockers, heads are closed chamber W2 race heads. The cam card says for 1.5 rockers to set the clearance at 0.020” hot, what’s recommended for 1.6 rockers cold please divide .020" by 1.5 and that's the clearance at the tappet; .0133". multiply .0133 by 1.6 and use that number for lash clearance to maintain the same ramp clearance that the 1.5 setting had; which would be .0213". This is correct, as well as what Cab states about expansion for iron and aluminum heads. So it's a 2 part answer factoring both the change in rocker ratio, and expansion, if you are trying to hit the cam card exactly.
[Re: mopar dave]
#2796137
07/13/20 12:07 PM
07/13/20 12:07 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I agree, i think its small peanuts. I tried those lash loops at the track when i had a 408 small block. Didn't see much if any gains with different small lash settings. I had open chamber w2's on it at one time and i do not remember the lash closing up with heat. The math that is suggested to get where you should be with your lash settings looks like the best advice here. I had great results changing lash, but i had some serious head and cam limitations. Iron 906 heads,535 cubes, and a .590 solid cam. That motor was desperate for air! With lash spec of .028 i had room, and .014 intake and .012 exhaust lash really helped! BUT- it was the dual problem of very poor heads and small cam that made those settings produce big gains. W2 heads with a cam that is well matched would be hard pressed to see any change at the track. A dyno session would be needed to see small changes.
