Re: what dist. for crank trigger?
[Re: Al_Alguire]
#279151
04/06/09 12:54 PM
04/06/09 12:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a Jesel front mouont distributor as well. but the Hemi uses a locked out MSD distributor. The only con about the front mount is the space it takes up and it limits water pump choices, I use a Meziere reverse flow unit in my car. Not a lot of room up front with it for me but it works.
Al, can you turn the dist around and have the cap facing the engine... would that allow for the clearance thats needed to clear the pumps
[Re: Chris Vanover]
#279152
04/06/09 01:14 PM
04/06/09 01:14 PM
Posts: 31,051 Oregon
AndyF
can i see some pics of the belt drive set up? i have a jesel belt drive... and where u get em and what do they cost?
I've posted a lot of stuff on belt drive distributors. Check in the best of area and/or the archives. I've posted some pictures showing how to use the Jesel distributor with a regular electric pump as well as a reverse flow unit.
[Re: rebel]
#279157
04/06/09 03:54 PM
04/06/09 03:54 PM
Posts: 2,864 IN
Irun5snd8th
IN
I use a stock distributor thats welded up on my small block. Works well.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Ari440]
#279161
04/06/09 06:30 PM
04/06/09 06:30 PM
AndyF
I usually make those plates with #12 AN o-ring fittings but I've also used 1 inch NPT and #16 AN o-ring.
The black anodized plates in the previous picture are a standard part number and pricing is on the webpage. The natural aluminum ones in the lower picture are a semi-custom part. The last pair I built was about $100 but it depends on how pretty a person wants them. I have a design that I think would work for most people but I just haven't built any parts for inventory yet. Shoot me a PM telling me what you need and I might have it on the shelf.
