what dist. for crank trigger? #279145
04/06/09 10:23 AM
04/06/09 10:23 AM
Pound, Va
Chris Vanover Offline OP
Pound, Va
what kind of distributors are you guys using w/ a crank trigger on a bb? i know u have to lock them down and really dont see the need to messing up a good msd dist. if i dont have to.
Re: what dist. for crank trigger? [Re: Chris Vanover] #279146
04/06/09 10:27 AM
04/06/09 10:27 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
You could use a lean burn distributor since they are already locked out and you could get one for next to nothing
Re: what dist. for crank trigger? [Re: Chris Vanover] #279147
04/06/09 10:50 AM
04/06/09 10:50 AM
AndyF Offline
AndyF  Offline
Nobody makes a crank trigger distributor for a BB Mopar for some reason. You can lock out a MSD fairly easy and it doesn't mess it up. The lean burn idea is also a good one if you can find an old distributor that is in okay shape. I use a belt drive distributor on my 505 but in order to do that you also need the Jesel belt drive set up.
Re: what dist. for crank trigger? [Re: AndyF] #279148
04/06/09 10:58 AM
04/06/09 10:58 AM
Pound, Va
Pound, Va
can i see some pics of the belt drive set up? i have a jesel belt drive... and where u get em and what do they cost?
Re: what dist. for crank trigger? [Re: Chris Vanover] #279149
04/06/09 11:34 AM
04/06/09 11:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use a Jesel front mouont distributor as well. but the Hemi uses a locked out MSD distributor. The only con about the front mount is the space it takes up and it limits water pump choices, I use a Meziere reverse flow unit in my car. Not a lot of room up front with it for me but it works.
Re: what dist. for crank trigger? [Re: Chris Vanover] #279150
04/06/09 12:20 PM
04/06/09 12:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
Call Jesel for the prices and kits
Re: what dist. for crank trigger? [Re: Al_Alguire] #279151
04/06/09 12:54 PM
04/06/09 12:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Al, can you turn the dist around and have the cap
facing the engine... would that allow for the clearance
thats needed to clear the pumps
Re: what dist. for crank trigger? [Re: Chris Vanover] #279152
04/06/09 01:14 PM
04/06/09 01:14 PM
AndyF Offline
AndyF  Offline
I've posted a lot of stuff on belt drive distributors. Check in the best of area and/or the archives. I've posted some pictures showing how to use the Jesel distributor with a regular electric pump as well as a reverse flow unit.
Re: what dist. for crank trigger? [Re: AndyF] #279153
04/06/09 01:17 PM
04/06/09 01:17 PM
AndyF Offline
AndyF  Offline
Here is one solution that I designed for a customer with a remote water pump. This setup works great and looks very professional when used with a custom radiator that accepts the dual #16 AN lines.
Re: what dist. for crank trigger? [Re: Chris Vanover] #279154
04/06/09 01:23 PM
04/06/09 01:23 PM
AndyF Offline
AndyF  Offline
Here is one way to use a standard electric pump with a belt drive distributor.
Re: what dist. for crank trigger? [Re: AndyF] #279155
04/06/09 03:05 PM
04/06/09 03:05 PM
Arkansas
defiance Offline
defiance  Offline
Arkansas
seconded on the MSD - it's made to be lockable, you just pull out the retainer pin, flip it around, and put the pin back in - done. Takes about 10-15 minutes and can be reversed just as quickly. I've switched mine back and forth a couple of times playing with ECU timing control vs. normal mechanical advance.
Re: what dist. for crank trigger? [Re: defiance] #279156
04/06/09 03:33 PM
04/06/09 03:33 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
if you don't want to go to the expense of buying an MSD to mod you can lock a Procomp dizzy just as easy & they're cheap to buy as well. thats what i did.
Re: what dist. for crank trigger? [Re: rebel] #279157
04/06/09 03:54 PM
04/06/09 03:54 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I use a stock distributor thats welded up on my small block. Works well.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: what dist. for crank trigger? [Re: Irun5snd8th] #279158
04/06/09 03:59 PM
04/06/09 03:59 PM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
I use a lean burn dist on mine works great.
Re: what dist. for crank trigger? [Re: B1HEAD_USER] #279159
04/06/09 04:29 PM
04/06/09 04:29 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
just a pain ole dist locked out/
Re: what dist. for crank trigger? [Re: AndyF] #279160
04/06/09 05:28 PM
04/06/09 05:28 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
what size is the lines ?
pm me a price on the plates , ANDY
1.39 9.85 - 137 mph
Re: what dist. for crank trigger? [Re: Ari440] #279161
04/06/09 06:30 PM
04/06/09 06:30 PM
AndyF Offline
AndyF  Offline
I usually make those plates with #12 AN o-ring fittings but I've also used 1 inch NPT and #16 AN o-ring.
The black anodized plates in the previous picture are a standard part number and pricing is on the webpage. The natural aluminum ones in the lower picture are a semi-custom part. The last pair I built was about $100 but it depends on how pretty a person wants them. I have a design that I think would work for most people but I just haven't built any parts for inventory yet. Shoot me a PM telling me what you need and I might have it on the shelf.
Re: what dist. for crank trigger? [Re: AndyF] #279162
04/06/09 08:29 PM
04/06/09 08:29 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I use a offset one from predator performance in Jersey.
BB, TT5,Procharged 3300lb Street Car 4.79/154
