Big hp lockup converter. #2787678
06/21/20 10:06 AM
06/21/20 10:06 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Does anyone know of a mutidisc lockup converter for 46rh through 47rh transmissions? I
I'm putting my 47rh/np205 combo together but the transmission guy doesn't think a single disc converter will hold with stroker hp and the weight of the truck. There is a lot out there for diesel, but stall speed is too low for the engine.
Re: Big hp lockup converter. [Re: Uberpube] #2787686
06/21/20 10:27 AM
06/21/20 10:27 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: Big hp lockup converter. [Re: Uberpube] #2788641
06/23/20 09:06 PM
06/23/20 09:06 PM
ohio
slomoshun Offline
slomoshun  Offline
ohio
If you find someone who will make one let me know. I’ve tried everyone I could think of
Re: Big hp lockup converter. [Re: Uberpube] #2788886
06/24/20 04:19 PM
06/24/20 04:19 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Precision of New Hampton inc
Re: Big hp lockup converter. [Re: HDNMOPERS] #2788899
06/24/20 04:45 PM
06/24/20 04:45 PM
tboomer Offline
tboomer  Offline
New Hampton Iowa? You got to be kidding.... shruggy
Re: Big hp lockup converter. [Re: tboomer] #2788905
06/24/20 05:03 PM
06/24/20 05:03 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
It looks like the way to do this is to run the compushift mini so you can map out the converter control to unlock it when your foot is in it. The standard 727 converter most likely doesn't have enpough room to get real clutch area in it. This is probably the reason for the larger bellhousing and converter on the later diesel and v10 motor applications.
Re: Big hp lockup converter. [Re: tboomer] #2788924
06/24/20 06:10 PM
06/24/20 06:10 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Never used them myself. But seen a build guy had a custom lock up vert for 200-4R to a SB Mopar with Reid Bell. But yeah New Hampton Iowa. Are they not very good converters? On their site it says they build Verts for the tranny he was asking about.
Re: Big hp lockup converter. [Re: HDNMOPERS] #2788949
06/24/20 07:10 PM
06/24/20 07:10 PM
tboomer Offline
tboomer  Offline
Thats around 13 miles north of me. I have never heard of them doing performance converters,Just rebuilds. If there was a good converter company I would think the guys at the track would have sais something. wave
Re: Big hp lockup converter. [Re: tboomer] #2788960
06/24/20 07:46 PM
06/24/20 07:46 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Check out their site. Heck 13 miles away go check them out.
Re: Big hp lockup converter. [Re: Uberpube] #2788988
06/24/20 09:02 PM
06/24/20 09:02 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Mo' Farts
Moderated by "tbagger".
Re: Big hp lockup converter. [Re: HDNMOPERS] #2789126
06/25/20 11:21 AM
06/25/20 11:21 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've had very good luck with Precision of New Hampton's triple, carbon fiber lock-up converters. I have a 3800rpm stall lock-up converter in my '68 and a 2500 rpm lock-up converter in my 2008 GMC 2500HD. Both perform flawlessly and I got great customer service and very quick turn around.
