Advance curve in a Hemi Distributor #2788408
06/23/20 10:40 AM
06/23/20 10:40 AM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Using a MSD distributor in a 433 Hemi, Stock crossram, small roller cam, mostly street 4 speed car. What would be a good advance curve and timing for this application. Lots of different choices with the MSD distributor. TIA
Re: Advance curve in a Hemi Distributor [Re: farmboy] #2788424
06/23/20 11:32 AM
06/23/20 11:32 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I WOULD START WITH ABOUT 15 INITIAL AND 32 TOTAL ALL IN ABOUT 2000 RPM
JAKES AUTOMOTIVE
Re: Advance curve in a Hemi Distributor [Re: farmboy] #2788427
06/23/20 11:36 AM
06/23/20 11:36 AM
central il.
second 70 Offline
second 70  Offline
central il.
My Hemi is locked out at 34 and starts fine. It would love more for cruising but 34 is the most it wants WOT. You would need vacuum advance or new programmable MSD to pull timing as rpm's increase.
Re: Advance curve in a Hemi Distributor [Re: farmboy] #2788440
06/23/20 12:25 PM
06/23/20 12:25 PM
Put the black bushing in and the lightest springs and set the total timing above 3000 RPM at 34 degrees and go have some fun up wrench twocents
You should have between 14 to 18 degrees at idle speed so it will start and idle good also scope
Re: Advance curve in a Hemi Distributor [Re: Cab_Burge] #2788465
06/23/20 01:39 PM
06/23/20 01:39 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Did just that, and I have a happy little engine now. Thanks guys
Re: Advance curve in a Hemi Distributor [Re: Cab_Burge] #2788468
06/23/20 01:41 PM
06/23/20 01:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My buddy’s 528 Barton Hemi was recommended at 30 total. We ran the old iron engine at 37, seemed to like it the best. Very light spring for start up then full at 800. The more advance the better the grunt and responsive down low
Re: Advance curve in a Hemi Distributor [Re: cudaman1969] #2788487
06/23/20 02:32 PM
06/23/20 02:32 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'd happily talk to you about jetting but we know how that goes. grin
'63 Dodge 330
11.19 @ 121 mph
Re: Advance curve in a Hemi Distributor [Re: Cab_Burge] #2788504
06/23/20 03:29 PM
06/23/20 03:29 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
iagree 100%
Re: Advance curve in a Hemi Distributor [Re: farmboy] #2788624
06/23/20 08:12 PM
06/23/20 08:12 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
On the dyno during break-in, my 540 liked 31* total. And I like as much initial as it will take until it starts to kick against the starter. The bumpier the idle, the more initial it likes. Right now, I think it is 25* initial and all in by 1,800.
Master, again and still
Re: Advance curve in a Hemi Distributor [Re: DaveRS23] #2788728
06/24/20 08:11 AM
06/24/20 08:11 AM
an8sec70cuda Offline
My 575" hemi likes 34°. I have it locked out and no trouble w/ starting. Idles better locked out too.
CHIP
'06 GMC 2500HD LBZ Duramax
