Can hydraulic roller lifters be run on a solid roller cam? #2775651
05/18/20 09:44 AM
05/18/20 09:44 AM
Guitar Jones Offline OP
I have a fairly mild solid roller Crane cam, 246/246 @ .050 with .3294 lobe lift, .527 lift with a 1.6 rocker that would fit my needs but I don't want to buy adjustable rockers and solid rollers. I have the bronze drive gear so that isn't a problem.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Guitar Jones] #2775702
05/18/20 12:47 PM
05/18/20 12:47 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Some say you can ! I run a hydralic roller cam 246 252 whit 1,6 592 576 and lobe sep 108 and use morell street lifters in a 505 4 speed and thats a fun ride in a Challenger drive
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Mopar Guy] #2775713
05/18/20 01:11 PM
05/18/20 01:11 PM
I have the Morell hydraulic lifters. I have seen on other sites where some say it depends on the rate of lift on the ramps. Too aggressive and it can hurt the lifter. I can see this if the body would come in contact with the lobe but otherwise I don't see why it would hurt them.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Guitar Jones] #2775719
05/18/20 01:31 PM
05/18/20 01:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I think Engine Masters had a recent episode on that, and the latest HotRod magazine has an article on that as well.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Guitar Jones] #2775744
05/18/20 02:21 PM
05/18/20 02:21 PM
Dude, what are you thinking shock tsk
Buy the good rocker arms and solid lifters or have that cam reground to hydraulic lifter specs twocents
You know Murphy loves you, don't you whistling haha
BTW, what is mild today was wild several years ago work
I built one 426 hemi motor for a customer with hydraulic roller lifters and cam in it, never again tsk twocents
AKA aside, buy the good parts and enjoy using the motor up Don't skimp tsk
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: topside] #2775745
05/18/20 02:22 PM
05/18/20 02:22 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
My thought from 40 years back was a Ford and Chevy you could not run a Hyd lifter on a Solid cam. The Mopar and AMC used the 0.904" lifter so the base did not dig into the cam lobes.
But with roller's I can not see any issues. The cam is stupid and does not know that is above it. It just sits there and spins.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Dave_J] #2775749
05/18/20 02:29 PM
05/18/20 02:29 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Hyd lifters on a solid cam?
Sure...... it’ll run.
Probably not too good though.
It’ll probably add about 30-40* of seat duration at the valve.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: fast68plymouth] #2775757
05/18/20 02:41 PM
05/18/20 02:41 PM
So you mean the valve will stay closed longer, effectively reducing the duration at .050 to the 206-216 degree area? It's a tight lash cam spec'd at .020 valve clearance.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Cab_Burge] #2775766
05/18/20 03:04 PM
05/18/20 03:04 PM
There's two problems with that. The available hydro cams all have too much lift for the other spec's I want. Namely duration in the mid 30's to 40's range and a tight LSA 107-109.
Secondly I already have the lifters
Thirdly OK, there's more than two problems, I need this thing back together and running so a custom grind is out of the question and
lastly, adjustable rockers and solid lifters are expensive. So I'm trying to make do with what I have. This is not a race car, it's my mountain truck. It has a ton of gear and a stick trans so I'm looking to work the engine at 3000-6000.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Guitar Jones] #2775767
05/18/20 03:14 PM
05/18/20 03:14 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
You can get adjustable iron rockers pretty cheap. For $150 or less you can get a set that would work for you................
You really need adjustable rockers even with a hydraulic roller cam in my experience - at least with the hyd roller I have.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: markz528] #2775776
05/18/20 03:34 PM
05/18/20 03:34 PM
It's a Magnum headed LA block. So yeah the rockers are cheap but then there are the studs, guide plates, then measuring for pushrods and ordering them and I'd still have to buy the solid roller lifters.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Guitar Jones] #2775777
05/18/20 03:34 PM
05/18/20 03:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
No..... I mean the exact opposite of that.
Running hyd lifters on a solid cam is the same as running it with zero lash......... because thats how much lash it will have....... zero.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: fast68plymouth] #2775779
05/18/20 03:39 PM
05/18/20 03:39 PM
So I would have 286 @.050 cam? That's way, way to much. laugh2
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Guitar Jones] #2775780
05/18/20 03:41 PM
05/18/20 03:41 PM
Would be more like a stocker cam with more lift.
Now that I've said that I kind of want to put it together and see how it runs. laugh2
I just don't have time to waste and I cant seem to get a cam.
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Guitar Jones] #2775928
05/18/20 08:05 PM
05/18/20 08:05 PM
Be careful of what you ask for work
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Guitar Jones] #2776466
05/20/20 01:03 PM
05/20/20 01:03 PM
Idaho
LaRoy Engines Offline
Idaho
I'm running hydraulic roller lifters on a street solid roller cam right now. It runs good but the idle is much rougher. Oh yeah...... I also run solid lifters on hydraulic cams. What? Am I the only one who does this crazy stuff?
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: LaRoy Engines] #2776547
05/20/20 05:44 PM
05/20/20 05:44 PM
Well I don't think this was a street cam despite the conservative lift so since I need to get this together and can't afford to waste a $450 lifter set I wussed out and ordered a hydraulic roller from Utawesome Performance. His grinds are the only ones I could find with more conservative lift figures for the 1.6 magnum rockers. Don't want to smash my valve seals or have some piston to valve intercourse.
BTW Marty at Utawesome was awesome. Great guy to deal with and he knows his magnums!
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: Guitar Jones] #2776570
05/20/20 07:19 PM
05/20/20 07:19 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
How have I never heard of this place? My Dakota R/T has been in the family for 18 years, and has lots of stuff done, all from the usual people.
I'll be calling him soon for a tuner and other stuff.
Thanks GJ!
Re: Can hydraulic roller lifters be run on a solid roller cam? [Re: A990] #2776572
05/20/20 07:27 PM
05/20/20 07:27 PM
Thanks GJ!
Just email them, and they will be in touch. I was a little nervous because there is no phone number on the website but he did contact me. He is a real stand up guy in my book.
