Can hydraulic roller lifters be run on a solid roller cam?
#2775651
05/18/20 09:44 AM
05/18/20 09:44 AM
Guitar Jones
I have a fairly mild solid roller Crane cam, 246/246 @ .050 with .3294 lobe lift, .527 lift with a 1.6 rocker that would fit my needs but I don't want to buy adjustable rockers and solid rollers. I have the bronze drive gear so that isn't a problem.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Can hydraulic roller lifters be run on a solid roller cam?
[Re: Mopar Guy]
#2775713
05/18/20 01:11 PM
05/18/20 01:11 PM
Guitar Jones
I have the Morell hydraulic lifters. I have seen on other sites where some say it depends on the rate of lift on the ramps. Too aggressive and it can hurt the lifter. I can see this if the body would come in contact with the lobe but otherwise I don't see why it would hurt them.
[Re: Guitar Jones]
#2775744
05/18/20 02:21 PM
05/18/20 02:21 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
I have a fairly mild solid roller Crane cam, 246/246 @ .050 with .3294 lobe lift, .527 lift with a 1.6 rocker that would fit my needs but I don't want to buy adjustable rockers and solid rollers. I have the bronze drive gear so that isn't a problem. Dude, what are you thinking Buy the good rocker arms and solid lifters or have that cam reground to hydraulic lifter specs You know Murphy loves you, don't you BTW, what is mild today was wild several years ago I built one 426 hemi motor for a customer with hydraulic roller lifters and cam in it, never again AKA aside, buy the good parts and enjoy using the motor Don't skimp
[Re: topside]
#2775745
05/18/20 02:22 PM
05/18/20 02:22 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
My thought from 40 years back was a Ford and Chevy you could not run a Hyd lifter on a Solid cam. The Mopar and AMC used the 0.904" lifter so the base did not dig into the cam lobes.
But with roller's I can not see any issues. The cam is stupid and does not know that is above it. It just sits there and spins.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2775749
05/18/20 02:29 PM
05/18/20 02:29 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Hyd lifters on a solid cam?
Sure...... it’ll run.
Probably not too good though.
It’ll probably add about 30-40* of seat duration at the valve.
[Re: fast68plymouth]
#2775757
05/18/20 02:41 PM
05/18/20 02:41 PM
Guitar Jones
It’ll probably add about 30-40* of seat duration at the valve. So you mean the valve will stay closed longer, effectively reducing the duration at .050 to the 206-216 degree area? It's a tight lash cam spec'd at .020 valve clearance.
[Re: Cab_Burge]
#2775766
05/18/20 03:04 PM
05/18/20 03:04 PM
Guitar Jones
I have a fairly mild solid roller Crane cam, 246/246 @ .050 with .3294 lobe lift, .527 lift with a 1.6 rocker that would fit my needs but I don't want to buy adjustable rockers and solid rollers. I have the bronze drive gear so that isn't a problem. Dude, what are you thinking Buy the good rocker arms and solid lifters or have that cam reground to hydraulic lifter specs You know Murphy loves you, don't you BTW, what is mild today was wild several years ago I built one 426 hemi motor for a customer with hydraulic roller lifters and cam in it, never again AKA aside, buy the good parts and enjoy using the motor Don't skimp There's two problems with that. The available hydro cams all have too much lift for the other spec's I want. Namely duration in the mid 30's to 40's range and a tight LSA 107-109. Secondly I already have the lifters Thirdly OK, there's more than two problems, I need this thing back together and running so a custom grind is out of the question and lastly, adjustable rockers and solid lifters are expensive. So I'm trying to make do with what I have. This is not a race car, it's my mountain truck. It has a ton of gear and a stick trans so I'm looking to work the engine at 3000-6000.
[Re: Guitar Jones]
#2775767
05/18/20 03:14 PM
05/18/20 03:14 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I have a fairly mild solid roller Crane cam, 246/246 @ .050 with .3294 lobe lift, .527 lift with a 1.6 rocker that would fit my needs but I don't want to buy adjustable rockers and solid rollers. I have the bronze drive gear so that isn't a problem. Dude, what are you thinking Buy the good rocker arms and solid lifters or have that cam reground to hydraulic lifter specs You know Murphy loves you, don't you BTW, what is mild today was wild several years ago I built one 426 hemi motor for a customer with hydraulic roller lifters and cam in it, never again AKA aside, buy the good parts and enjoy using the motor Don't skimp There's two problems with that. The available hydro cams all have too much lift for the other spec's I want. Namely duration in the mid 30's to 40's range and a tight LSA 107-109. Secondly I already have the lifters Thirdly OK, there's more than two problems, I need this thing back together and running so a custom grind is out of the question and lastly, adjustable rockers and solid lifters are expensive. So I'm trying to make do with what I have. This is not a race car, it's my mountain truck. It has a ton of gear and a stick trans so I'm looking to work the engine at 3000-6000. You can get adjustable iron rockers pretty cheap. For $150 or less you can get a set that would work for you................ You really need adjustable rockers even with a hydraulic roller cam in my experience - at least with the hyd roller I have.
[Re: markz528]
#2775776
05/18/20 03:34 PM
05/18/20 03:34 PM
Guitar Jones
It's a Magnum headed LA block. So yeah the rockers are cheap but then there are the studs, guide plates, then measuring for pushrods and ordering them and I'd still have to buy the solid roller lifters.
[Re: Guitar Jones]
#2775777
05/18/20 03:34 PM
05/18/20 03:34 PM
fast68plymouth
So. Burlington, Vt.
It’ll probably add about 30-40* of seat duration at the valve. So you mean the valve will stay closed longer, effectively reducing the duration at .050 to the 206-216 degree area? It's a tight lash cam spec'd at .020 valve clearance. No..... I mean the exact opposite of that. Running hyd lifters on a solid cam is the same as running it with zero lash......... because thats how much lash it will have....... zero.
#2775779
05/18/20 03:39 PM
05/18/20 03:39 PM
Guitar Jones
It’ll probably add about 30-40* of seat duration at the valve. So you mean the valve will stay closed longer, effectively reducing the duration at .050 to the 206-216 degree area? It's a tight lash cam spec'd at .020 valve clearance. No..... I mean the exact opposite of that. Running hyd lifters on a solid cam is the same as running it with zero lash......... because thats how much lash it will have....... zero. So I would have 286 @.050 cam? That's way, way to much.
[Re: Guitar Jones]
#2775780
05/18/20 03:41 PM
05/18/20 03:41 PM
Guitar Jones
Would be more like a stocker cam with more lift. Now that I've said that I kind of want to put it together and see how it runs. I just don't have time to waste and I cant seem to get a cam.
[Re: Guitar Jones]
#2775928
05/18/20 08:05 PM
05/18/20 08:05 PM
Cab_Burge
Would be more like a stocker cam with more lift. Now that I've said that I kind of want to put it together and see how it runs. Be careful of what you ask for
[Re: Guitar Jones]
#2776466
05/20/20 01:03 PM
05/20/20 01:03 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
I'm running hydraulic roller lifters on a street solid roller cam right now. It runs good but the idle is much rougher. Oh yeah...... I also run solid lifters on hydraulic cams. What? Am I the only one who does this crazy stuff?
[Re: LaRoy Engines]
#2776547
05/20/20 05:44 PM
05/20/20 05:44 PM
Guitar Jones
I'm running hydraulic roller lifters on a street solid roller cam right now. It runs good but the idle is much rougher. Oh yeah...... I also run solid lifters on hydraulic cams. What? Am I the only one who does this crazy stuff? Well I don't think this was a street cam despite the conservative lift so since I need to get this together and can't afford to waste a $450 lifter set I wussed out and ordered a hydraulic roller from Utawesome Performance. His grinds are the only ones I could find with more conservative lift figures for the 1.6 magnum rockers. Don't want to smash my valve seals or have some piston to valve intercourse. BTW Marty at Utawesome was awesome. Great guy to deal with and he knows his magnums!
[Re: Guitar Jones]
#2776570
05/20/20 07:19 PM
05/20/20 07:19 PM
Posts: 2,730 541 slobovia
A990
541 slobovia
BTW Marty at Utawesome was awesome. Great guy to deal with and he knows his magnums! How have I never heard of this place? My Dakota R/T has been in the family for 18 years, and has lots of stuff done, all from the usual people. I'll be calling him soon for a tuner and other stuff. Thanks GJ!
[Re: A990]
#2776572
05/20/20 07:27 PM
05/20/20 07:27 PM
Guitar Jones
BTW Marty at Utawesome was awesome. Great guy to deal with and he knows his magnums! How have I never heard of this place? My Dakota R/T has been in the family for 18 years, and has lots of stuff done, all from the usual people. I'll be calling him soon for a tuner and other stuff. Thanks GJ! Just email them, and they will be in touch. I was a little nervous because there is no phone number on the website but he did contact me. He is a real stand up guy in my book.
