Multiple Gauges - Where to get power from?
#277454
04/05/09 12:49 AM
04/05/09 12:49 AM
Posts: 1,075 United States
STLDuster
United States
I am working on installing a Tach, Temp and Oil Pressure gauge in my '74 Duster. I have everything squared away except where to get the power from for all 3 gauges.
I want to wire them in so they only get power when the key is in the "run" posistion. Do I splice in to a power wire 3 times?
What/Where is the best way to wire in multiple gauges?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Multiple Gauges - Where to get power from?
[Re: farmington]
#277456
04/05/09 01:38 AM
04/05/09 01:38 AM
Posts: 3,903 Oregon
hooziewhatsit
In my 72 pickup I mounted my new gauges in the old dash. I found which wire was switched power coming to the cluster, and tapped off the circuit board there.
Now I can just unplug the one cable and still pull the cluster out. (I also re-used the existing fuel, oil, and water temp wires)
-Dave
[Re: Dart 340]
#277458
04/05/09 11:32 PM
04/05/09 11:32 PM
STLDuster
United States
Found it! Thanks for all the help! This picture is from the other day, still have a ton of work to do. I can only tackle it one part at a time. Thanks!
[Re: STLDuster]
#277459
04/06/09 12:50 AM
04/06/09 12:50 AM
Posts: 189 Plano, Texas
Dallasdart
Plano, Texas
ahh yesss. Looks very familiar, using the fuse pannel is best. Someday I want to make my own dash using the redline dash.
72 Dart Swinger 360 Project
