Multiple Gauges - Where to get power from? #277454
04/05/09 12:49 AM
04/05/09 12:49 AM
United States
STLDuster Offline OP
United States
I am working on installing a Tach, Temp and Oil Pressure gauge in my '74 Duster. I have everything squared away except where to get the power from for all 3 gauges.
I want to wire them in so they only get power when the key is in the "run" posistion. Do I splice in to a power wire 3 times?
What/Where is the best way to wire in multiple gauges?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Multiple Gauges - Where to get power from? [Re: STLDuster] #277455
04/05/09 12:52 AM
04/05/09 12:52 AM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
Tie all 3 wires together and tap into power at the fuse block. Just find a cavity that's only hot in the run position.
Re: Multiple Gauges - Where to get power from? [Re: farmington] #277456
04/05/09 01:38 AM
04/05/09 01:38 AM
hooziewhatsit Offline
In my 72 pickup I mounted my new gauges in the old dash. I found which wire was switched power coming to the cluster, and tapped off the circuit board there.
Now I can just unplug the one cable and still pull the cluster out. (I also re-used the existing fuel, oil, and water temp wires)
-Dave
Re: Multiple Gauges - Where to get power from? [Re: farmington] #277457
04/05/09 10:25 AM
04/05/09 10:25 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
You should have an open 1/4" spade terminal on the
top of your fuse block open to tap into. If you
have a wiring diagram for your car it will show it
and also the always live terminals and keyed ones.
Re: Multiple Gauges - Where to get power from? [Re: Dart 340] #277458
04/05/09 11:32 PM
04/05/09 11:32 PM
United States
United States
Found it!
Thanks for all the help!
This picture is from the other day, still have a ton of work to do. I can only tackle it one part at a time.
Thanks!
Re: Multiple Gauges - Where to get power from? [Re: STLDuster] #277459
04/06/09 12:50 AM
04/06/09 12:50 AM
Plano, Texas
Dallasdart Offline
Dallasdart  Offline
Plano, Texas
ahh yesss. Looks very familiar, using the fuse pannel is best. Someday I want to make my own dash using the redline dash.
72 Dart Swinger 360 Project
