Re: Steering column: tree shift to floor shift conversion
[Re: hemienvy]
#2773067
05/10/20 05:03 AM
05/10/20 05:03 AM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
Once you make the change to floor shift column, the orange wire running to ignition switch plug will arrive nowhere. Will stay on female plug and won get nothing on male plug. That's how factory made it. So just need to remove the column shifter light wire and terminal from ignition switch plug.
The console needs to get couple of wires from the dash wiring provision up to console shifter assembly with a socket in the end. This wire runs from the source on dash harness ( rubber orange feed ) on bullet terminal, up to passenger side kick panel area with female packard terminal, then another wire from there ( male packard of course ) up to console down the carpet, with a socket for #57 bulb
[Re: NachoRT74]
#2773068
05/10/20 05:19 AM
05/10/20 05:19 AM
NachoRT74
Valencia, España
This is the source you'll find somewhere down the dash to feed the console shifter light ( mostly sure at driver side ) And this is the repro wiring available for it Repro shifter light wires on ebay
