727 column shift linkage the same? Thanks
#2767752
04/24/20 08:06 AM
04/24/20 08:06 AM
Posts: 777 Washougal,Wa
Dodge
Washougal,Wa
is small block and big block 727 column shift linkage the same? What year range for a 70 satellite? Thanks Terry
Stand behind your word
Re: 727 column shift linkage the same? Thanks
[Re: Dodge]
#2767891
04/24/20 04:50 PM
04/24/20 04:50 PM
Posts: 76 Pittsburgh, PA
roadrunnerh
Pittsburgh, PA
My understanding is the column shift linkage needs to fit or be compatible with the car regardless of 904/727. For example, I'm using the factory column shift setup on my 75 Scamp that originally had 225/904/7.25 but will now have 383/727/8.75. You should be looking into 68-70 column shift B Bodies.
Harry 1968 Road Runner 1975 Scamp
