727 column shift linkage the same? Thanks #2767752
04/24/20 08:06 AM
04/24/20 08:06 AM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
is small block and big block 727 column shift linkage the same? What year range for a 70 satellite? Thanks Terry
Stand behind your word
Re: 727 column shift linkage the same? Thanks [Re: Dodge] #2767891
04/24/20 04:50 PM
04/24/20 04:50 PM
Pittsburgh, PA
roadrunnerh Offline
roadrunnerh  Offline
Pittsburgh, PA
My understanding is the column shift linkage needs to fit or be compatible with the car regardless of 904/727.
For example, I'm using the factory column shift setup on my 75 Scamp that originally had 225/904/7.25
but will now have 383/727/8.75.
You should be looking into 68-70 column shift B Bodies.
Harry
1968 Road Runner
1975 Scamp
Re: 727 column shift linkage the same? Thanks [Re: Dodge] #2767894
04/24/20 05:00 PM
04/24/20 05:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 model year steering columns are unique to the 1970 model year.
Re: 727 column shift linkage the same? Thanks [Re: Alaskan_TA] #2767901
04/24/20 05:41 PM
04/24/20 05:41 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I'd imagine the LA and B/RB engine 727 linkage is the same.
904 stuff is different from 727 stuff.
Re: 727 column shift linkage the same? Thanks [Re: Neil] #2767925
04/24/20 08:01 PM
04/24/20 08:01 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Thanks for the help
