Any roots gasoline guys here? #2765557
04/18/20 04:42 PM
04/18/20 04:42 PM
Great Neck,LI,new york
hemi-itis Offline OP
My data logger is showing me IAT's of 165* or more where my power just goes flat. I want to intercool with nitrous and a plate will not work because the throttle blade hits the crossbar at 1/3 to open.I want to install a pair of fogger nozzles in the 1 inch spacer plates.
Has anyone used juice to intercool??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Ant roots gasoline guys here? [Re: hemi-itis] #2765580
04/18/20 05:34 PM
04/18/20 05:34 PM
Me thinks you are tempting faith, why not use a water /meth injection or straight methanol injection set up instead twocents work
Re: Ant roots gasoline guys here? [Re: Cab_Burge] #2765595
04/18/20 06:16 PM
04/18/20 06:16 PM
I went this way,the Nitrous tech has come a long way! Can tune each nozzle from 50 hp which is I want to start with up to 175HP each.This will lower the IAT bt over 100*!!!!! W/M can't do that whistling
https://www.ebay.com/itm/Nitrous-Ou...trksid=p2349526.m4383.l4275.c10#viTabs_0
Re: Ant roots gasoline guys here? [Re: Cab_Burge] #2765737
04/19/20 12:50 AM
04/19/20 12:50 AM
Superfreak
Superfreak
Or a Whipple. whistling
Re: Ant roots gasoline guys here? [Re: ] #2765995
04/19/20 03:42 PM
04/19/20 03:42 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
This may provide some information, if you haven't seen it already.
https://www.youtube.com/watch?v=B-AreBlwVrY
Re: Ant roots gasoline guys here? [Re: blowndart] #2766033
04/19/20 05:28 PM
04/19/20 05:28 PM
Way to many hand actions for me to watch very long, wanna be actors down
Re: Ant roots gasoline guys here? [Re: blowndart] #2766109
04/19/20 09:10 PM
04/19/20 09:10 PM
Thanks Jim/ I watched till the end,BUT,,,,,That's for a turbo,is 10 lbs of turbo boost the the same or equal to 10 Lbs of roots boost. Will that data be the same as the nitrous will cool the blower case but not the actual turbo temp . work
Re: Ant roots gasoline guys here? [Re: hemi-itis] #2766156
04/19/20 11:31 PM
04/19/20 11:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
10 lbs on either set up is 10lbs but the temp wont be.. you have a much bigger heat sink
wave
Re: Ant roots gasoline guys here? [Re: hemi-itis] #2766254
04/20/20 11:40 AM
04/20/20 11:40 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Call Induction Solutions and ask for Steve Johnson to call you back. IM sure they have done this, customer service from this guy is unreal, he will help you every step of the way, all the way to track tuning.
....BAD A$$ STREET CAR.....
Re: Ant roots gasoline guys here? [Re: hemi-itis] #2766291
04/20/20 12:41 PM
04/20/20 12:41 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
A spacer below your carbs would put you on the road
Re: Ant roots gasoline guys here? [Re: hemi-itis] #2766351
04/20/20 03:19 PM
04/20/20 03:19 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Turbo vs. roots not the same.
Many (conservative) turbo applications have backpressure = boost × 2. This means the chamber is not fully purged each cycle - yours is. With the same manifold pressure a roots has higher combustible charge mass (less exhaust products).
Boffin Emeritus
Re: Ant roots gasoline guys here? [Re: Cab_Burge] #2766677
04/21/20 12:02 PM
04/21/20 12:02 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
haha His animated delivery is very hard to take. The guy churns out a lot of content and mostly devoted to power adder stuff, but it's hard to watch.
Re: Ant roots gasoline guys here? [Re: blowndart] #2766807
04/21/20 04:35 PM
04/21/20 04:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I watched it but it was hard.. I dont think he stopped with the hands
wave
Re: Ant roots gasoline guys here? [Re: n20mstr] #2766944
04/21/20 10:28 PM
04/21/20 10:28 PM
Your right Tony,he gave me a thumbs up and said it will work .
I have to decide placement of the nozzle in the spacer plate,not sure if it's not spraying right into the middle if it will effect distribution after going through the blower rotors.Also the carb adapter is necked down.I would think it could flow better with flat sides like the carb spacer.
Re: Ant roots gasoline guys here? [Re: Clanton] #2766949
04/21/20 10:33 PM
04/21/20 10:33 PM
I spoke to Pat at Pro Systems,he did not like the idea of 2.5 spacer plates.He suggested perimeter plates at $750 a pair.These fogger nozzles are $70 each,more suited to my no budget improvements. violin
Re: Ant roots gasoline guys here? [Re: hemi-itis] #2767027
04/22/20 09:14 AM
04/22/20 09:14 AM
N
n20mstr Offline
n20mstr  Offline
N
Al, if you have the nozzles, and need help setting them up and install.....I guess your on your way over to Thriftway to see Joe ? or you should be.....
Good luck and stay safe !
Re: Ant roots gasoline guys here? [Re: hemi-itis] #2767030
04/22/20 09:18 AM
04/22/20 09:18 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am glad to see you found some direction on what to do and picked a path.
Re: Ant roots gasoline guys here? [Re: n20mstr] #2767037
04/22/20 09:32 AM
04/22/20 09:32 AM
I have the tap,just have to figure where to install it today! Thriftway is a ZOO!!
Thanks for the referral Tony. Joe and his brother & father are good people! up
Re: Ant roots gasoline guys here? [Re: Clanton] #2767039
04/22/20 09:33 AM
04/22/20 09:33 AM
Mike,will you ever put yours back on??
Re: Ant roots gasoline guys here? [Re: hemi-itis] #2767053
04/22/20 10:46 AM
04/22/20 10:46 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Yes as soon as I put in the trans and test it n/a around the block
