Any roots gasoline guys here?
#2765557
04/18/20 04:42 PM
04/18/20 04:42 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
My data logger is showing me IAT's of 165* or more where my power just goes flat. I want to intercool with nitrous and a plate will not work because the throttle blade hits the crossbar at 1/3 to open.I want to install a pair of fogger nozzles in the 1 inch spacer plates. Has anyone used juice to intercool??
Re: Ant roots gasoline guys here?
[Re: blowndart]
#2766109
04/19/20 09:10 PM
04/19/20 09:10 PM
hemi-itis
Thanks Jim/ I watched till the end,BUT,,,,,That's for a turbo,is 10 lbs of turbo boost the the same or equal to 10 Lbs of roots boost. Will that data be the same as the nitrous will cool the blower case but not the actual turbo temp .
[Re: hemi-itis]
#2766254
04/20/20 11:40 AM
04/20/20 11:40 AM
Posts: 4,684 On the parachute mount
n20mstr
My data logger is showing me IAT's of 165* or more where my power just goes flat. I want to intercool with nitrous and a plate will not work because the throttle blade hits the crossbar at 1/3 to open.I want to install a pair of fogger nozzles in the 1 inch spacer plates. Has anyone used juice to intercool?? Call Induction Solutions and ask for Steve Johnson to call you back. IM sure they have done this, customer service from this guy is unreal, he will help you every step of the way, all the way to track tuning.
....BAD A$$ STREET CAR.....
[Re: hemi-itis]
#2766351
04/20/20 03:19 PM
04/20/20 03:19 PM
Posts: 4,209 New York
polyspheric
New York
Turbo vs. roots not the same. Many (conservative) turbo applications have backpressure = boost × 2. This means the chamber is not fully purged each cycle - yours is. With the same manifold pressure a roots has higher combustible charge mass (less exhaust products).
Boffin Emeritus
[Re: n20mstr]
#2766944
04/21/20 10:28 PM
04/21/20 10:28 PM
hemi-itis
My data logger is showing me IAT's of 165* or more where my power just goes flat. I want to intercool with nitrous and a plate will not work because the throttle blade hits the crossbar at 1/3 to open.I want to install a pair of fogger nozzles in the 1 inch spacer plates. Has anyone used juice to intercool?? Call Induction Solutions and ask for Steve Johnson to call you back. IM sure they have done this, customer service from this guy is unreal, he will help you every step of the way, all the way to track tuning. Your right Tony,he gave me a thumbs up and said it will work . I have to decide placement of the nozzle in the spacer plate,not sure if it's not spraying right into the middle if it will effect distribution after going through the blower rotors.Also the carb adapter is necked down.I would think it could flow better with flat sides like the carb spacer.
[Re: Clanton]
#2766949
04/21/20 10:33 PM
04/21/20 10:33 PM
hemi-itis
A spacer below your carbs would put you on the road I spoke to Pat at Pro Systems,he did not like the idea of 2.5 spacer plates.He suggested perimeter plates at $750 a pair.These fogger nozzles are $70 each,more suited to my no budget improvements.
[Re: hemi-itis]
#2767027
04/22/20 09:14 AM
04/22/20 09:14 AM
n20mstr
Al, if you have the nozzles, and need help setting them up and install.....I guess your on your way over to Thriftway to see Joe ? or you should be.....
Good luck and stay safe !
[Re: n20mstr]
#2767037
04/22/20 09:32 AM
04/22/20 09:32 AM
hemi-itis
I have the tap,just have to figure where to install it today! Thriftway is a ZOO!! Thanks for the referral Tony. Joe and his brother & father are good people!
[Re: Clanton]
#2767039
04/22/20 09:33 AM
04/22/20 09:33 AM
hemi-itis
I am glad to see you found some direction on what to do and picked a path. Mike,will you ever put yours back on??
[Re: hemi-itis]
#2767053
04/22/20 10:46 AM
04/22/20 10:46 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Yes as soon as I put in the trans and test it n/a around the block I am glad to see you found some direction on what to do and picked a path. Mike,will you ever put yours back on??
