Re: Painting the engine compartment with the engine in? [Re: Kirby] #276263
04/06/09 04:20 PM
04/06/09 04:20 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Depends ...
Are you going to fix that rot on the inner fender? If not then paint the whole thing with a brush 'cause everyone will be looking at the rot, not the paint !!
Re: Painting the engine compartment with the engine in? [Re: Kirby] #276264
04/06/09 05:48 PM
04/06/09 05:48 PM
Kentucky
Hillbillyracer Offline
mopar addict
mopar addict
Kentucky
Granted- pulling the engine will give you the best results. A trick I learned- is to use aluminum foil to wrap your motor and parts. It conforms to whatever you are wrapping, and does not get blown around from the air pressure. You can really wrap things tight, and have much more room to get your paint down in the nooks and crannies.
That is a good idea,never thought of that
1972 Dodge dart,,1964 Plymouth Valiant station wagon,1976 Dodge M880 truck,1995 Dodge 3500 rollback
Re: Painting the engine compartment with the engine in? [Re: cudabitten] #276265
04/06/09 10:20 PM
04/06/09 10:20 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Just like taking a shower with your cothes on !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
