Difference between a 68 & 69 Charger dash? #2753604
03/19/20 07:27 PM
03/19/20 07:27 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Is there a difference between the 69 and 68 Dodge Charger dash? Inwas told the dash pad is different.
Re: Difference between a 68 & 69 Charger dash? [Re: WS68SSC] #2753610
03/19/20 07:37 PM
03/19/20 07:37 PM
New York
rarefish Offline
rarefish  Offline
New York
The finish on the face to the dash was different. The 68 had thin vertical lines or ribes and the 1969 dash face was a like a "moulded pebble" finish.
Here is a pic of the dash in a 68 Charger that I owned. In 1969 the SE package got you the wood-grain finish on the dash.
As I recall there was no difference in the dash pads.
Re: Difference between a 68 & 69 Charger dash? [Re: rarefish] #2753616
03/19/20 07:52 PM
03/19/20 07:52 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The TOP dash pad is different: '68 has kind of a blade, peaked in the center; '69-'70 got a more rounded/beveled face.
I don't recall a lower pad difference '68 vs '69, but if so, it might be the simulated stitching.
Re: Difference between a 68 & 69 Charger dash? [Re: topside] #2753619
03/19/20 08:03 PM
03/19/20 08:03 PM
New York
rarefish Offline
rarefish  Offline
New York
I won't dispute it. I have to will admit that I never compared the two. Thanks for the correction...
Re: Difference between a 68 & 69 Charger dash? [Re: rarefish] #2753624
03/19/20 08:13 PM
03/19/20 08:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
No worries, OP didn't say which dash pad.
I always forget the cluster face difference on those.
Re: Difference between a 68 & 69 Charger dash? [Re: WS68SSC] #2753632
03/19/20 08:38 PM
03/19/20 08:38 PM
I think the 1969 dash had a small difference around the headlight switch, maybe not confused
Re: Difference between a 68 & 69 Charger dash? [Re: Cab_Burge] #2753662
03/19/20 10:32 PM
03/19/20 10:32 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
the ignition switch hole is a different size
Re: Difference between a 68 & 69 Charger dash? [Re: topside] #2753664
03/19/20 10:34 PM
03/19/20 10:34 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Yes - totally correct ^^^. 1968 is all by itself.
Re: Difference between a 68 & 69 Charger dash? [Re: rarefish] #2754675
03/22/20 06:23 PM
03/22/20 06:23 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
If memory serves me right, the 68 instrument panel has the Dodge Emblem (three pointed star) in the middle top.
Re: Difference between a 68 & 69 Charger dash? [Re: maximus] #2755028
03/23/20 01:37 PM
03/23/20 01:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep.
Re: Difference between a 68 & 69 Charger dash? [Re: John_Kunkel] #2755375
03/24/20 10:58 AM
03/24/20 10:58 AM
moparx Offline
moparx  Offline
refresh my memory please.
what was the removable [?] plate below the fuel gauge used for ? [as always, a big TIA !]
beer
Re: Difference between a 68 & 69 Charger dash? [Re: moparx] #2755382
03/24/20 11:08 AM
03/24/20 11:08 AM
N
NITROUSN Offline
NITROUSN  Offline
N
beer
I think the rear defogger switch went there in 68. The rear speaker fader control also went someplace on the dash.
Re: Difference between a 68 & 69 Charger dash? [Re: maximus] #2755516
03/24/20 04:33 PM
03/24/20 04:33 PM
New York
rarefish Offline
rarefish  Offline
New York
It has been discuss a lot in the past, but the belief is that the 68 Chargers built in the 1st. half of the model year had the "bulls eye" emblem and the Chargers built in the 2nd half got the "Fratzog" (three pointed star) emblem.
Re: Difference between a 68 & 69 Charger dash? [Re: rarefish] #2755755
03/25/20 11:44 AM
03/25/20 11:44 AM
moparx Offline
moparx  Offline
thanks for the info and pic guys ! bow [and for also refreshing my old, foggy memory]
beer
Re: Difference between a 68 & 69 Charger dash? [Re: moparx] #2755765
03/25/20 12:07 PM
03/25/20 12:07 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
beer
Easiest way to rEfReSh that ... is to hook up oleHam2 to 440 volts ! grin
