Re: Difference between a 68 & 69 Charger dash?
[Re: WS68SSC]
#2753610
03/19/20 07:37 PM
03/19/20 07:37 PM
Posts: 2,252 New York
rarefish
New York
The finish on the face to the dash was different. The 68 had thin vertical lines or ribes and the 1969 dash face was a like a "moulded pebble" finish. Here is a pic of the dash in a 68 Charger that I owned. In 1969 the SE package got you the wood-grain finish on the dash. As I recall there was no difference in the dash pads.
[Re: topside]
#2753619
03/19/20 08:03 PM
03/19/20 08:03 PM
rarefish
New York
The TOP dash pad is different: '68 has kind of a blade, peaked in the center; '69-'70 got a more rounded/beveled face. I don't recall a lower pad difference '68 vs '69, but if so, it might be the simulated stitching. I won't dispute it. I have to will admit that I never compared the two. Thanks for the correction...
[Re: Cab_Burge]
#2753662
03/19/20 10:32 PM
03/19/20 10:32 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
the ignition switch hole is a different size
[Re: topside]
#2753664
03/19/20 10:34 PM
03/19/20 10:34 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
The TOP dash pad is different: '68 has kind of a blade, peaked in the center; '69-'70 got a more rounded/beveled face. I don't recall a lower pad difference '68 vs '69, but if so, it might be the simulated stitching. Yes - totally correct ^^^. 1968 is all by itself.
[Re: moparx]
#2755382
03/24/20 11:08 AM
03/24/20 11:08 AM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
refresh my memory please. what was the removable [?] plate below the fuel gauge used for ? [as always, a big TIA !] I think the rear defogger switch went there in 68. The rear speaker fader control also went someplace on the dash.
[Re: maximus]
#2755516
03/24/20 04:33 PM
03/24/20 04:33 PM
rarefish
New York
If memory serves me right, the 68 instrument panel has the Dodge Emblem (three pointed star) in the middle top. It has been discuss a lot in the past, but the belief is that the 68 Chargers built in the 1st. half of the model year had the "bulls eye" emblem and the Chargers built in the 2nd half got the "Fratzog" (three pointed star) emblem.
