a dumb question but curious #2754320
03/21/20 08:48 PM
03/21/20 08:48 PM
wilmington,ohio
O
ohiodemon Offline OP
O
wilmington,ohio
has anyone ever swapped a 351 based ford engine into an a-body duster/demon ?
Re: a dumb question but curious [Re: ohiodemon] #2754321
03/21/20 08:50 PM
03/21/20 08:50 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If your fever & other symptoms continue, please seek medical help?
Re: a dumb question but curious [Re: Alaskan_TA] #2754322
03/21/20 08:51 PM
03/21/20 08:51 PM
wilmington,ohio
O
O
wilmington,ohio
lol, i just wondering, maybe the effects of coronavirus ?
Re: a dumb question but curious [Re: ohiodemon] #2754329
03/21/20 09:10 PM
03/21/20 09:10 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Heard they fit the Chevy Chevelle SS 396 chasses good.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: a dumb question but curious [Re: Dave_J] #2754337
03/21/20 09:37 PM
03/21/20 09:37 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
The only guy that did is in jail for Meth possession... shruggy
...FAFO...
Re: a dumb question but curious [Re: skicker] #2754379
03/22/20 12:29 AM
03/22/20 12:29 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I doubt anyone's crazy enough to do that swap: less power & more problems...
Re: a dumb question but curious [Re: ohiodemon] #2754382
03/22/20 12:39 AM
03/22/20 12:39 AM
Windsor or Cleveland?
I'm thinking both have front sump oil pans correct work scope
Re: a dumb question but curious [Re: Cab_Burge] #2754384
03/22/20 12:44 AM
03/22/20 12:44 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I do not think that would be a good thing to do or attempt. How many small block Chrysler were built and still being built. People would rather swap a Gen 3 Hemi with wiring harness and all other parts to make it run like a new vehicle. But I know of a few that have swapped an SRT4 Turbo into a Fox Body Mustang making it a rear wheel drive. None of these Brand X changes I would do.
1971 HEMI E BODY REGISTRY
Re: a dumb question but curious [Re: hemicar1971] #2754388
03/22/20 01:08 AM
03/22/20 01:08 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Maybe I'm mistaken and remembering this wrong, but wasn't there someone here with a Dart with a paint scheme sort of like a P 51 Mustang that had a Ford motor?
Re: a dumb question but curious [Re: ohiodemon] #2754390
03/22/20 01:16 AM
03/22/20 01:16 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Seems plausible if you had a nicely worked up one already w/trans. And if you were replacing a worn/beaten 318, 6-cyl, or a smog 360.
Would love to see the looks on the Mopar Crazys faces at a show
Re: a dumb question but curious [Re: ohiodemon] #2754395
03/22/20 02:40 AM
03/22/20 02:40 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Only a moron with a very limited scope of common sense and intellect.
Re: a dumb question but curious [Re: Jjs72D] #2754416
03/22/20 08:15 AM
03/22/20 08:15 AM
wilmington,ohio
O
O
wilmington,ohio
lol, the motor i have is a 420 cid stroker windsor dyno'd at 787 hp. so its a no joke engine trans is a g force 101a. body is a 71 duster very straight and very clean.
just thinking. probably too much trouble.
Re: a dumb question but curious [Re: ohiodemon] #2754425
03/22/20 09:00 AM
03/22/20 09:00 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mount it on a plate. The biggest issue is probably the oil pan with the steering linkage. May need a tube thru the pan? The K frame is easy to cut . Custom headers. Maybe late 5.7 Hemi headers with the flanges cut and reworked?
Doug
Re: a dumb question but curious [Re: ohiodemon] #2754433
03/22/20 09:19 AM
03/22/20 09:19 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i disagree with the neg comments about this swap.
doing this swap is what old time hot rodding is all about.
making what you have fast with what you have available to you. i say GO FOR IT.
after saying that, it won't be a easy swap and you won't get much help doing it. so be prepared before you start.
perception is 90% of reality
Re: a dumb question but curious [Re: ohiodemon] #2754446
03/22/20 10:08 AM
03/22/20 10:08 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Ford engines in our Mopars?!?!?! What's next? Ford 9" rears in our Mopars?
Master, again and still
Re: a dumb question but curious [Re: DaveRS23] #2754448
03/22/20 10:14 AM
03/22/20 10:14 AM
BDW Offline
BDW  Offline
This is where some 3D modeling software would really tell the story.
If someone develops engines models, it would be easy to “drop it in” and see where the issues are.
Re: a dumb question but curious [Re: BDW] #2754453
03/22/20 10:25 AM
03/22/20 10:25 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Lol
It's called a tape measure and it's already done.
The 351w is 1/2" wider, 4" shorter and essentially the same height.
Re: a dumb question but curious [Re: DaveRS23] #2754475
03/22/20 11:28 AM
03/22/20 11:28 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Exactly up I would round out the swap with a 9" Ford type rear with ZERO factory parts used and then you would have a bulletproof drive train with that G-force box and the track proven stroker Ford engine. Wrap all that up in a Duster with a 4-link and you have a very nice consistent drag car.
Go for it man drive
Gus beer
64 Plymouth Savoy
Dana 60
Re: a dumb question but curious [Re: DaveRS23] #2754476
03/22/20 11:28 AM
03/22/20 11:28 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Mopars in Vzla use to get their K member and suspension replaced by the GM half chassis and suspension system ( Novas and Caprice ). I also have seen Ford axles and 350 engines on them... so yes, it can be worst.
Re: a dumb question but curious [Re: NachoRT74] #2754508
03/22/20 12:09 PM
03/22/20 12:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d probably chose to just make life easier for myself.
If I “had” to use that motor, I’d find a Ford product to put it in.
There are several Ford bodies I like well enough to use.
