Re: Magnum top end reassembliy ????
[Re: 540challenger]
#275239
04/02/09 07:52 PM
04/02/09 07:52 PM
Posts: 7,506 Az
Crizila
Az
Head bolts = 105lbs. If you have had the block decked, you might want to verify the bolts don't bottom in the holes. Mine did and I had to use head bolt washers to keep the bolts from bottoming in the holes. Mopar Performance sells a valve lash adjustment chart decal that you can stick under the hood. Makes it nice and simple and you don't miss any. Intake manifold bolts = 45lbs.
Fastest 300
[Re: Crizila]
#275240
04/02/09 07:54 PM
04/02/09 07:54 PM
Posts: 2,826 NY usa
540challenger
NY usa
Thanks for the specs. I was aware of them bottoming out and check All is good so far.
[Re: Crizila]
#275242
04/02/09 08:26 PM
04/02/09 08:26 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
if you are using a magnum intake on magnum heads then the intake bolt torque is 12 nm. almost nothing
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: 70AARcuda]
#275245
04/02/09 10:26 PM
04/02/09 10:26 PM
RapidRobert
Magnum intake torquing pattern. front to rear pass side is 10-6-2-4-7-11. Drivers side front to rear 9-5-1-3-8-12. torque bolts 1-4 in the sequence in 12 inch lb increments to 72 inch lbs. Then the remaining bolts to 72 inch lbs(in sequence). Check that ALL are at 72 inch lbs. If not tighten them up to 72 in sequence. Then tighten ALL bolts to 144 inch lbs in sequence & recheck.
[Re: 540challenger]
#275250
04/03/09 11:08 AM
04/03/09 11:08 AM
RapidRobert
This this method apply tojust the stock intake or an afermarket i have a air Gap manifold??
It would apply to both as torque specs are about the particular bolt being used to get it to the right amount of stretch & the 12 ft lbs would be for the stock type bolts & not sure if the angle(vertical) affects this also.
[Re: RapidRobert]
#275251
04/03/09 11:48 AM
04/03/09 11:48 AM
Posts: 2,826 NY usa
540challenger
NY usa
thanks again
