Magnum top end reassembliy ???? #275238
04/02/09 05:38 PM
04/02/09 05:38 PM
NY usa
540challenger Offline OP
NY usa
Hey guys i am putting back together the top end on my magnum/LA small block and have some questions.
What is the correct torque for the magnum headbolts
" iam using 30W oil on the threads and under the head of the bolt." and are they torque in the same pattern as an LA engine?
Also when i am setting the valve lash i set the intake valve while the exhaust is closing?
Then the exhaust valve while when the intake is opening??
last question i swear.
What is the torque on the intake bolts.
Thanks guys
Re: Magnum top end reassembliy ???? [Re: 540challenger] #275239
04/02/09 07:52 PM
04/02/09 07:52 PM
Az
Crizila Offline
Crizila  Offline
Az
Head bolts = 105lbs. If you have had the block decked, you might want to verify the bolts don't bottom in the holes. Mine did and I had to use head bolt washers to keep the bolts from bottoming in the holes. Mopar Performance sells a valve lash adjustment chart decal that you can stick under the hood. Makes it nice and simple and you don't miss any. Intake manifold bolts = 45lbs.
Fastest 300
Re: Magnum top end reassembliy ???? [Re: Crizila] #275240
04/02/09 07:54 PM
04/02/09 07:54 PM
NY usa
NY usa
Thanks for the specs. I was aware of them bottoming out and check All is good so far.
Re: Magnum top end reassembliy ???? [Re: 540challenger] #275241
04/02/09 08:05 PM
04/02/09 08:05 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
how far do you have to go to bottom out the bolts? I had my block (Magnum) squared, but I guess the machinist took very little off (or that's what he said).
Re: Magnum top end reassembliy ???? [Re: Crizila] #275242
04/02/09 08:26 PM
04/02/09 08:26 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
if you are using a magnum intake on magnum heads then the intake bolt torque is 12 nm. almost nothing
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Magnum top end reassembliy ???? [Re: blk00rt] #275243
04/02/09 08:55 PM
04/02/09 08:55 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Like tightening a spark plug ?
Re: Magnum top end reassembliy ???? [Re: sharpie] #275244
04/02/09 09:24 PM
04/02/09 09:24 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
use harden washers under head bolts.
Tony
70 AARCuda Vitamin C
Re: Magnum top end reassembliy ???? [Re: 70AARcuda] #275245
04/02/09 10:26 PM
04/02/09 10:26 PM
Magnum intake torquing pattern. front to rear pass side is 10-6-2-4-7-11. Drivers side front to rear 9-5-1-3-8-12. torque bolts 1-4 in the sequence in 12 inch lb increments to 72 inch lbs. Then the remaining bolts to 72 inch lbs(in sequence). Check that ALL are at 72 inch lbs. If not tighten them up to 72 in sequence. Then tighten ALL bolts to 144 inch lbs in sequence & recheck.
Re: Magnum top end reassembliy ???? [Re: RapidRobert] #275246
04/03/09 12:09 AM
04/03/09 12:09 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Robert,
Does 144 inch/pounds equals to 12 foot pounds &?
We won't get confused by the conversion........
Dan
Re: Magnum top end reassembliy ???? [Re: Wedgeman] #275247
04/03/09 12:12 AM
04/03/09 12:12 AM
yes
Re: Magnum top end reassembliy ???? [Re: RapidRobert] #275248
04/03/09 08:02 AM
04/03/09 08:02 AM
NY usa
NY usa
thankk for the info. This this method apply tojust the stock intake or an afermarket i have a air Gap manifold??
Re: Magnum top end reassembliy ???? [Re: sharpie] #275249
04/03/09 08:33 AM
04/03/09 08:33 AM
Az
Crizila Offline
Crizila  Offline
Az
I think I had to have .015" taken off my block to get the deck height I wanted. All the bolt holes in my LA block were not taped ( 1/2-13 ) the same depth, nor were they the same depth period. The top row of bolt holes was deep enough - barely. The bottom row had some deep enough and some not quite deep enough. I put hardened head bolt washers on all of them. Thanks for the correction on the manifold bolt torque - although 12nm seems ( "almost nothing") as does 144 inch lbs. Had my Magnum heads drilled to accept both styles and I am presently using an LA style manifold with them. Ether way, I'm using grade 8 5/16-18 bolts - 30ft lb capacity. Assume the angle on the Magnum bolt pattern requires considerable less torque?
Fastest 300
Re: Magnum top end reassembliy ???? [Re: 540challenger] #275250
04/03/09 11:08 AM
04/03/09 11:08 AM
It would apply to both as torque specs are about the particular bolt being used to get it to the right amount of stretch & the 12 ft lbs would be for the stock type bolts & not sure if the angle(vertical) affects this also.
Re: Magnum top end reassembliy ???? [Re: RapidRobert] #275251
04/03/09 11:48 AM
04/03/09 11:48 AM
NY usa
NY usa
thanks again
