Stock cam and lifter package recommendation for stock 440+6 #2750737
03/10/20 12:40 PM
03/10/20 12:40 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
Rebuilding a stock 440 six pack engine. It's been a number of years since I did this and I recall the mopar performance stuff was junk. What manufacturer and camshaft are you engine guys using for a stock rebuild?
I would even consider a step or 2 hotter, but want to keep stock exhaust and decent vacuum.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: RSI700VIPER] #2750768
03/10/20 02:51 PM
03/10/20 02:51 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
I've heard only good things about Bob Karakashian (‘Mr Six Pack’) cams but have never used one myself. Phone 248-477-7776.
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: RSI700VIPER] #2750780
03/10/20 03:45 PM
03/10/20 03:45 PM
one of the two Summit house brands
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: RapidRobert] #2750797
03/10/20 05:21 PM
03/10/20 05:21 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
In one of my 440s I ran an Engle hydraulic FT dual-pattern, about 234/244 @ .050 and a bit over .500 lift.
Great manners, a bit healthier than stock, very tractable with 4-speed & fairly tall final gear.
Also ran the EDM lifters (oiling hole), 1.5 roller rockers, 10.2 CR with Eddy heads, Maxie manifolds & full exhaust.
Just avoid the long-duration stuff.
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: RapidRobert] #2750813
03/10/20 06:54 PM
03/10/20 06:54 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I second RR's suggestion of Summit Racing's cams. I have both cams and love them. I use the smaller cam in my pickup with an auto, stock convertor and 3.23 gears. It runs great. I use the bigger cam in a 66 b-body with factory high stall convertor, 3.55 gears. The specs are .445/.465 lift, 214/224 duration @.050 for the small cam and .466/.488 lift, 224/234 duration @.050 for the larger. They both have excellent street manners. The larger cam has a slight lope at idle and pulls hard in a 440 with 9.2 compression, 452 heads and factory intake. A little more compression, better heads and intake would really wake it up.
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: elmor353] #2750831
03/10/20 09:25 PM
03/10/20 09:25 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
Mr six pack
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: elmor353] #2750914
03/11/20 08:44 AM
03/11/20 08:44 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
this has been my experience. I would look no further than the 6401 cam with good lifters and crane 99839 springs.
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: lewtot184] #2751025
03/11/20 02:55 PM
03/11/20 02:55 PM
E
elmor353 Offline
elmor353  Offline
E
I used those same Crane valve springs. Perfect for the 6401 cam.
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: elmor353] #2751065
03/11/20 05:38 PM
03/11/20 05:38 PM
NW New Jersey
NW New Jersey
Appreciate all the feedback. Thanks!
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: 1969gtx] #2751096
03/11/20 08:29 PM
03/11/20 08:29 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Originally Posted by 1969gtx
Mr six pack
iagree
Bob K's cam specs are hard to come by but they are "very" close to the old Direct Connection Street Hemi grind 280 / 474
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: 62maxwgn] #2751207
03/12/20 10:58 AM
03/12/20 10:58 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I went with the Lunati 60302 cam in my wife's 440 six Pack Challenger.
https://www.summitracing.com/parts/lun-60302
Fresh rebuilt 440 engine with Stealth aluminum heads and stock Six Pack setup.
Mild Daaco HP converter and 3.23 rear.
Engine is a great cruiser, lots of low and mid range power with great vacuum.
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: KillerBee] #2751235
03/12/20 12:20 PM
03/12/20 12:20 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
I second that Lunati cam. It's in my '71 GTX with a six barrel. "Mini Mayhem"-love what they call it.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: 62maxwgn] #2751238
03/12/20 12:25 PM
03/12/20 12:25 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Mr six pack
iagree
some years back bob k. gave the specs to his cam. they were engles at that time and I regret throwing that magazine away that had an article about his car. anyhow, from what I remember his cams are no where near that old '214 cam. from what i remember his cams are pretty mild. unfortunately people tout these cams but nobody degrees one in to know the specs or have any track times to put with the specs. I did use a hughs/engle 2330 once in a 6pak and it worked pretty good. down side to the 2330 is the lift requires shortening the valve guide boss's for retainer to seal/guide clearance. a summit 6401 using factory retainers and the crane springs is pretty much a no-brainer with factory valvetrain. hopefully someday somebody will put a degree wheel and some track times on the bob k. cams.
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: RSI700VIPER] #2751254
03/12/20 01:05 PM
03/12/20 01:05 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Maybe Crower 271HDP. Allmost the same to the Lunati suggested but a bit more Exhaust duration and bit more Intake lift. I'm using 282HDP and is just a bit lumpy but plenty for a street car with A/C ( allmost street values on good vacuum and iddle ). So I think one step lower will be more stockish iddle if you want that
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: NachoRT74] #2751257
03/12/20 01:12 PM
03/12/20 01:12 PM
Kirkland, Washington
Pacnorthcuda Offline
I run the Lunati that is one step hotter than the one already mentioned. Old part number 60303. .493/.513. 70 440 Cuda, power brakes, 4 speed.
I get 11inhg vacuum. Just enough for reliable brakes, but that’s all dependent on your idle rpm. Mine is at 750rpm.
With an automatic I would recommend at least a 2200rpm stall (which is still pretty tight, a lot of stock converters will easily stall this high behind a 440).
Power band goes to about 6200, high enough for me.
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: Pacnorthcuda] #2751262
03/12/20 01:37 PM
03/12/20 01:37 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I installed a Hughes HEH 1928 BL . Very happy with it, Stock manifolds, 9.14:1 CR with quench pistons, 3.55 gears, 727, 6 bbl carbs. CR is a critical parameter when selecting a Camshaft.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Stock cam and lifter package recommendation for stock 440+6 [Re: RSI700VIPER] #2751392
03/12/20 08:40 PM
03/12/20 08:40 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
You won't go wrong with anything recommended, IMO. Any 218° - 224° @ 0.050" on the intake and with a 112° - 114° LSA will work well with what your doing. Picking the best one in that range will be splitting hairs.
I used the MP 272 - 0.455" cam (221° @ 0.050 w/ 112°lsa) in a 4200 lb, 6bbl, exhaust manifold, car w/ 3.23 and went high 12s at 108+ mph.
